Hi
Car stared running very rough then stalled soon after. A code p12a8 was read in the reader.
Car will now crank but not start after clearing code.
Done so Far
-checked as many electical connections as possible
-checked for fuel to injectors
-replaced battery as voltage was low 11.9 (possibly due to cranking but battery was also old)
-reset BSI multiple times
-tested all fuses
-recent replacement of throttle body. Put old throttle body back on to see if this caused the error.
-checked hoses and vacuum lines for leaks .
Now the code reader does not pick up any codes. The car cranks and almost seems like it will fire but fails. Not sure where to go next. Fuel pump? I'm concerned that it could be an ECU failure but as it seems like it's trying to fire I'm not sure.
Any help would be appreciated.
Done so Far
-tested all fuses
