You have to be extremely careful throwing things int the sea..BECAUSE THEY WILL SAY IT CAUSED GLOBAL WARMING AND THE SEA LEVEL RISING...WHY..BECAUSE NOTHING HAS DONE SO YET..HAS IT ???/NO IT HAS NOT CHEERS.
Hi all. I hope someone out there can help me. i have a 505 GTi 1990 wagon. she was running perfectly. a few months ago, i decided to try to fix the dash panel under the drivers side, which was hanging a bit low, making it really difficult to access the bonnet release. zip tied a few things up to solid bars, carefully avoiding any wiring. (double checking this, all seems fine) drove her a short distance - all ok. the next day, started beautifully as ever, but wont rev past about 1750, missing, backfiring and almost cutting out. thus started the checking and replacing! replaced plugs, no change, checked them and all fine. tested HT leads, fine. pulled dizzy cap off, seemed fine, no cracks. fuel is fine. checked for air leaks, none. seems we have tried everything and nothing is making a difference. i think a few other things were checked, but i cant remember now! one website suggests it is often the last thing you did before having problems, ie under the dash. is there anything under there that could be causing this problem? thanks in advance if you can help. Michele.
