Heading home from shops all of a sudden the accelerator stuck. I controlled the run away beast by riding the brakes until I was able to pull over and switch off the engine. On restarting, the engine revs went sky high!
Eventually found the floor mat had caught under the accelerator pedal. Managed the journey home with no further excitement.
After about an hour I went back to the 504, re-arranged the floor mat and started the engine, an unholy din erupted from under the bonnet! After a short idle the noise went away I then went for a short run, no more noises while on the move.
All sorts of things are by then going through my mind [a short journey]. I visualised a cracked or broken piston, a big end, oil light going out normally, a cracked exhaust? Unable to get under to examine this one.
I then carried out a compression test more in hope than desperation, all readings good and even. The week old plug tips were white with no oil. A vacuum test showed my original setting with no variations.
I have been able to drive the 504 for couple of days now and apart from the start up racket it goes normally.
Now, my final thought is that the auto drive plate has cracked contributing to the start up noise but nothing on driving. I'm wondering if the strain on both the engine and trans on my holding the stuck throttle with the brake has caused this or any other damage ?
Anyone??
Anyone??
