The ute is being a bit cantankerous. It's a 2L with the dual throat Solex.
Starts on full choke, runs fast then dies, rinse & repeat a couple more times then it's fine.
I've also had issues with the needle valve: sometimes it jams shut (relieved by tapping with the back of a screwdriver) & sometimes it jams open (fuel dripping out the throttle valve spindle) but I think that's a separate issue. The carb specialist who reco'd it is getting me a new valve.
Fearing debris in the tank, I installed an inline filter.
Now as I understand fuel pumps, they only go one way. So, if the filter empties after switching off, the fuel must be draining back into the tank. That can't be right! There would be a spring loaded flap valve on the delivery side that SHOULD stop fuel going backwards, yes?
It's a sealed unit so there's no repairing it I guess?
