- Joined
- Sep 6, 2003
- Messages
- 700
??? I suggest that R8/R10 style diagonal trailing arms do have a significant role in controlling toe changes. What makes you suggest otherwise?
I still remember my first ride in a friend's R8. And then when we bought our own, just what a capable vehicle I realised it was (and is, come to think of it, albeit a bit dated now). I still enjoy it several times every week.Hmm 4CVG and John,
The times when I had my first 750s was when I was an apprentice and had no money, living away from home too. My only engineering was done at work by smuggling stuff in/out in my bag, and on the street or down at the servo car park where we hung out. So replacing a couple of trunion bushes was easy enough every now and again and cheap. Possibly bronze bushes would have been better but then I was not aware they were available. I did lop a coil or two off the rear springs at work.
But us Renault owners did look at the leading arms and with the benefit of a short education so far and observations realised that they were second best, at best, but you could get them at the wreckers. One person made up some leading arms that angled in onto the rear cross member but the details escape me now. I think there were relocations required. He always pointed out how much better it was but who knows ?? The 750s would leave a side valve Morrie or Hillman for dead in all respects, a Standard 10. Even a Berkley and a Gogo Dart which apprentices had as cheap cars then. Possibly equal to a VW.I also had a motor cycle for cheap transport home. I walked to work.
So what was the point again ? Ahh the rubber bushes on the leading arms covered 'a multitude of sins' as they say. In this case allowing some give and take. But it was the sixties and generally cheap easy to fix cars to get around in were the norm. Racing or hooning was frowned upon by decent people !! But who had the money anyway. I joined a car club and had a bit of fun and learned a bit, met Murray Bingham and learned a bit more about Renaults and going faster too. He was the guru around here then.
But we all moved on with more knowledge and books and learning. But the R8 was a revelation, showing the direction to go. I had possibly destroyed all my 750s by then, but continuous repair did teach me a lot of manual skills. As I said I had met some slightly older guys who lived nearby and had served their apprenticeship with the local Renault, Citroen ++ dealer. They were helpful and offered advice and ideas and even parts to help. Particularly when I bought a Traction B15 that was cheap too !! Another story.
Jaahn
PS the short 10 mins for editing is annoying. I always now do the editing before i send !!
Yes, that's pretty much what I was saying, and Jaahn. The early ones were poor regarding longevity, and I suspect mostly due to the materials available/used for the pins. The later ones are larger but probably a better grade of steel. My bronze bushes rotate only on the outside, so are bigger again.Well, here's your data. Compare wear in the trunion bushings/bearings in the R8 after 360kkm to the ones in the 4CV after 10kkm. Would be interesting. I am sure the OEM design of the 4CV was "good enough" but I also have a suspicion it was not done with longevity in mind. Or not with the longevity we expected in the sixties at least, let alone today. The R8/10 and others have no such problems. As for toe changes and relative movement of the rear axle to the front (geometry) alignment changes, I think the car was light enough and had too little power to suffer from the side effects. Whatever little movement there may have been, could have been absorbed by the entire system (rubber mounts, etc) before the tubes moved in the trunions. Either way, something has to give and I guess the trunion bushings will eventually wear faster than the ones on a car with control arms.
Also keep in mind, a .1mm play at the trunion becomes a few mm at the wheel, which translates in a serious toe change. Probably not important as said above in the overall context of the car (mass, grip, power, etc.) but significant if you are used with modern handling (I include here the R10 and similar cars, not much younger than the 4CV).
Hmm quite some years back 12-15 perhaps I drove a 750 'barn find' unrestored. It went OK but slow, however the wandering in a straight line scared me. Even in the back streets at 50Km it scared me and I declined to go faster on to the by-pass. I knew what the problem was and how easy it was to fix but nah not for me even then. I have driven newer better cars for too long to go back to that. As you say an R10 seems like a new car compared to that.===
Yes, unless it is a late 750, you'd be very lucky to have acceptable trunnions. I have several sets of later swing axles and they are all unmarked on the pins or quite free of side play. I reckon they just got the steel right on the later ones, although the greater diameter can hardly hurt. The caps are too hard to drill with anything I've found!Hmm quite some years back 12-15 perhaps I drove a 750 'barn find' unrestored. It went OK but slow, however the wandering in a straight line scared me. Even in the back streets at 50Km it scared me and I declined to go faster on to the by-pass. I knew what the problem was and how easy it was to fix but nah not for me even then. I have driven newer better cars for too long to go back to that. As you say an R10 seems like a new car compared to that.
In the same vein from 30 years before I was offered a good EH Holden and test drove that, and was singularly unimpressed by everything about it and just walked away. I was driving R12s at that time.
Jaahn
Good question! Years ago, I had an idea of fitting grease nipples to the trunnion bearings but actually with their end seal, the caps seem to keep the needles clean and the light grease stays in place. I've just pulled a 60-year old one apart and it was perfectly clean, unworn and greased. I'm pretty sure it had never been touched from new.Why do you need to drill the cap?
Carbide will go through any kind of steel you are likely to encounter including fully hardened tool steel. Not cheap, but if you need the job done, that's the way.
Thanks. Learn something every day. This time "threading size drill"!!Not that hard to drill and tap. My suspicion (based on other similar car components) is that the outer layer is hardened but the inside is soft so once you're in, it should be easy. Carbide drill bit to punch through, chamfer hole and follow with threading size drill and finally tap. Carbide drill bits are expensive but they last and are the only thing that will cut through. Only needs steady hand so you don't break it. Sure, it's much easier on a lathe but for such a simple job not absolutely necessary.
Dunno exactly, don't have any early ones with rollers. Substantial grooves is right!would be interesting to know if the early trunnions had larger and fewer rollers i recall mine had quite substantial grooves in them were the roller had been hammering when hitting pot holes etc ,a larger number of smaller diameter rollers is going to spread the load ,and possibly have less tendency to branell [put dings in] the pivot PUGS
