Can anyone suggest a fix for my problem.I have a 2005 407 HDi 2.0 4 speed Auto. I had a small leek from water reservoir and drained the coolant to repaired same, refilled with coolant and now the radiator fan will not come on when the temperature is 90 degrees, even when the engine temperature reaches 106 degrees. My first thought was an air bubble so I refilled with coolant another 2 times, no luck. Took the car to Nat Rad radiator specialists and they pressure tested the system and assured me that there were no air pockets and the system check out OK. Driving home temperature goes to 106 degrees. My next thought was that the temperature sensor had failed or thermostat had stopped opening, so I bought a new thermostat housing with a new temperature sensor checked both thermostat and sensor and they were both working fine, I installed unit; the damn thing is still overheating and the fan still will not come on due to engine temperature but the fan comes on when I engage the Air-Condition and the engine temperature does NOT come down!!Help
