Hi all,
Long time frogger, first time to share a project.
Yesterday my dad and I received our tinkering project of a 1963(i believe) 404 wagon! It had 3 owners before us, and the last owner had is sitting in a shed since the early 80's.
Body is quite good apart from some small surface rust on the roof and the odd panel, but underneath looks pretty good.
Paint will look ok after we give it a cut and polish, but will need a spray eventually.
Engine won't turn over and the brakes are not functioning. Door rubbers need replacing and seats need re-upholstering.
We were fiddling around this afternoon with a bit of "let's take the bonnet off so its easier to get to the engine when we get there". Then "let's take the radiator out so its easier to get to the engine when we get there".
Before we knew it we had the head off! I have some mechanical knowledge, and dad has had Peugeots since as long as I can remember. We will try and get the pistons free and see what happens from there. Dad has already fashioned up some washers to keep the sleeves in place.
Here is a photo of the head. What do you think? Rebuild or see if we can source a second hand head. Being a '63, I believe the engine is a 1618cc 3 bearing? Gearbox would be a C3?
Oh and dad mentioned something about he thinks the Welsh(?) plug is missing in the head behind the water pump? Could this be?
I don't think 30+ years of sitting has done much good for the engine...
So should we get the head done or find a second hand one?
Another option is we also have a 2 litre 504 engine which has had some cam work done for a rally some years ago. Would it be as easy as just dropping it in? Does it bolt straight on to the C3 gearbox? I have read some post on AF, but I'm still not sure how easy the transplant is. I read the 2 litre can mess with the gearing etc, but it would be a quick fix for the meantime. We would like to try and keep it as 404 as possible.
We have found Scott's Auto rubbers for the doors etc. What about engine gasket kits for the 1600?
And we need an ignition barrel. It must have broken in the past and one of the owners had installed a on off switch with a starter button under the dash. Where could I find the ignition barrel?
Anyway thanks for reading. I hope I can continue to keep updates happening. I'm sure it will slow down from here on in.
Thanks in advance and we look forward to hearing from you.
Evan
Evan
