It's not often I need help on the forum but this is doing my head in.
Car is my 1959 403
When I restored it I checked all the brakes, rear were fine but fronts were warn out so I had the shoes rebonded and fitted new wheel cylinders and it's been good for a while.......but.....
A little while ago the pedal went to the floor and I had to pump it up to get home and some horrid noises coming from the rear.
The rear bonding had come away and the metal shoe was rubbing on the drum, the bonding on the right rear had failed so I had both rear brakes rebonded and drums machined and all back together.
I can't get a pedal, pump like mad and it come up but sinks straight back to the floor.
Has to be the old rust in the bore of the master cylinder trick, that's the second time I've fallen for it.
Remove master cyl and sure enough there's rust in there as suspected,
while it was away being fixed I found a new one on ebay so I now have 2.
I fitted the reco one first and bled it and bled it and I'm sure there's no air but still no pedal, still the same, no pedal but after pumping the crap out of my legs I could finally get a pedal but 2 seconds after I stop the pedal has gone again, jest like a faulty master cylinder.
So I tried the brand new one and it's exactly the same.
What am I missing? The adjustment is right from what I remember about adjusting 4 wheel drums that the drum is just spinning and lightly scraping the shoes. All 4 are like that.
I've got it on stands with all 4 wheels off, there's no limit valve on these old things is there? There's something I'm not seeing.
I'm going to have a wine now while I wait for some expert advise.
Car is my 1959 403
