Hi I have a 306 Rallye with a RFV series motor. It has a crank wont start issue. The fuel pump plug has no voltage. if i supply power to the pump it runs and the engine fires. I have swapped the relay for another but they could both well be dodgy. How do i check the continuity of the wire from the pump to the relay? I have power to pin number 14. I have tried bridging pins 5 and 8 and the fuel pump didnt run - are these the right ones? Also, I am not getting any power to the fuel pump and o2 sensor fuses to the under bonnet fuse box near the battery when the ignition is turned on. I am thinking that the fuse would be before the relay, is this also wrong of me? Is it possible that just the fuel circuit is not getting power from the ignition switch or something like that. Any help would be appreciated. Cheers David.
