• Tapatalk and Mobile iOS/ Android APPs no longer supported on aussiefrogs.com. Please delete on your device. Use the web interface instead.
306 Brake waring light
dhaw
Getting the brake warning light on the 306's dash. New pads all round and wiring to them intact. Blown and shorted bulbs attended to 4 weeks ago that seemed to be giving the warning light. All bulbs working. Fluid level OK. What else can I look at?
lowpugV2
Active member
Purely a guess, but the brake switch behind the pedal, under the dash can go. You need to be an octopus to change it out easily though.
lowpugV2
Active member
Also, ABS system? The abs pump or whatever sensors it uses could have gone. Also, is the wiring to the brake fluid reservoir ok?
John505
Look at the wire to the pads and check that it has not frayed anywhere along its path and come into contact with the chassis. That is what happened to my 405.
Best of luck
John505
