Howdy,
I didn't want to post this in my other thread because it might not be seen by the smart people who have given up on my rantings there.
I ran some diagnostics with my Foxwell NT204 and got the following relevant results:
FROM COLD-ISH, IDLING CIRCA 850 RPM
FUELSYS1 = CL (I know this means closed loop, so OK)
LOADPCT = 3.5
SHRTFT1(%) = around 0, fluctuation up and down to circa 8% either way (+/-)
LONGFT1 (%) = >+30 up to around 40 (indicating lean I believe)
MAP(kPa) = 37
O2B1S1(V) = around 0.7
SHRTFTB1S1(%) = around 0.8 fluctuating (not sure what this should be)
02B1S2(V) = 0.4 to 0.8 fluctuating
SHRTFTB1S2 (%) = N/A
AT CIRCA 2,000 RPM
FUELSYS1 = CL
LOADPCT = 5.1
SHRTFT1(%) = around +48, fluctuation up and down a little
LONGFT1 (%) = around 0 fluctuating up to -7
MAP(kPa) = 24
O2B1S1(V) = around 0.8
SHRTFTB1S1(%) = around +48 fluctuating
02B1S2(V) = Didn't record this...oops.
DROPPED BACK TO IDLE AND SETTLED
SHRTFT1(%) = around -6 to -10
LONGFT1(%) = +39
During the 2000 rpm stint, a code was stored; P0170 - Fuel Trim Bank 1. The Check Engine MIL was lit.
Freeze frame data was:
RPM = 1601 (note it is difficult to keep stable at 2000)
ECT = 60C (this is about right; it hadn't fully warmed)
FUELSYS1 = CL
LOADPCT = 5.9
SHRTFT1(%) = +48.4
MAP(kPa) = 34
SHRTFT3 (%) = -100
LONGFT1(%) = -7.8
LONGFT3 (%)= -100
OK, so firstly it seems the ECU is compensating for a lean condition. My first port of call is that I'm getting my son to take a fuel pressure gauge home from work and I'll check the rail pressure static and running, especially since the pump is makng a weird thump when priming first thing. I wouldn't think the filter is blocked but....? I'll replace it anyway in case.
My thinking is that the duty cycle is bumped up because the pressure is below spec and not as much fuel as required is passing through the injectors while open.
Secondly, my internet searches suggest the 'bank' 3 data from the freeze frame may be spurious data thrown up by a non manufacturer specific reader, but none of the three or four sources for this were reliable (ie. not a tech of some sort) so could be just repeated BS. But if not, what is bank 3? It only has two O2 sensors.
So, I'm thinking fuel pressure or a dodgy upstream O2 sensor, but the latter shouldn't affect starting should it? I think the O2 sensor voltages look OK, too.
Oh well, it's all a good learning experience!
I welcome any comments as this is all new to me.
Stuey
Edit: I looked through the receipts and there's an invoice for a fuel filter in 2012 around 20,000km ago so (as long as it was done!) it's probably not this.
LOADPCT = 3.5
MAP(kPa) = 37
AT CIRCA 2,000 RPM
FUELSYS1 = CL
LOADPCT = 5.1
MAP(kPa) = 24
LONGFT1(%) = +39
FUELSYS1 = CL
LOADPCT = 5.9
SHRTFT1(%) = +48.4
MAP(kPa) = 34
SHRTFT3 (%) = -100
LONGFT1(%) = -7.8
LONGFT3 (%)= -100
Stuey
