I recently had a wheel alignment done on my 205 gti after fitting kw coilovers and bm baker adjustible top mounts. When I set up the camber so it was equal on both sides I noted that on the LHS the strut was at maximum while the RHS was at the midway point.
SAI Steering Axis Inclination on the LHS is 55' RHS is 12 degrees 45'. The lhs has had a hit at some stage in the past I have replaced the lower control arm in the time I have had the car.
Has anyone got any suggestions how I can fix the problem?
