205 brake Line Details
PugMonkey
Well-known member
Can anyone help with some brake line and fittings info please?
I want to get rid of the fixed rear compensators in favor of an adjustable bias valve. I'll need to know what line size is standard, flare type and thread size to keep everything the same throughout the fittings.
I will remove one of the lines from the master cylinder and use a "T" fitting after the valve so all good on that front too.
Thanks for any help.
Remove from car, take to brake place and they will make one up easily.
No mix up in thread types :)
im pretty sure they are m10x1 also and if your flaring the pipes yourself they should be double flared for brakes.
FYI the original peugeot lines are hard as hell and can crack if you dont have a good quality flare tool.
