- Joined
- Aug 2, 2000
- Messages
- 11,440
Aah, I see what you mean now.
You can pack these bearings out if you have a removeable carbon.
This was done a lot in order to use the 9 spring 404 clutch plate, just a thought, you don't have a 404 clutch do you?
The 203 one has 6 springs.
Reducing the free play does not make any difference as the release fork still cannot go beyond the end of the slot to provide more release. I am left with three possibilities - worn thrust, clutch plate too thick or incorrectly adjusted fingers. I gave the specs to the rebuilder who provided a new driven plate and reconditioned the pressure plate. As the specs indicate a range of two mm for the plate thickness I have just about ruled that possibility out. Again, the specified total movement at the thrust is 1.5 mm. If I could bring the fingers up by an amount within that measurement the problem might be solved. Has anyone done this before?
