Hi, I know the hard lengthy way to remove the radiator. But can the V6 radiator come out without removing the bumper bar? Also how do I remove the radiator from the cradle easily? There's so little information on the net.
Im very competent and can figure it all out, but the process of working things out is time consuming, I am sure that some of you good people have got it down to a t, and can help me with your knowledge.
Last time I had to replace the water manifold close to the cat, I removed the front bar, and then the complete rad/condenser cradle dropped out easily from the bottom, rather than lifting it from the top.
I am hoping that the radiator is easily separated from the cradle and I can extract it without spending hours stripping away.
thanking you in advance.
Roy.
Roy.
