Hi All
2008 PEUGEOT 308 T7 1.6L EP6DT (5FX) DOHC 16v Turbo Petrol Direct Inj. 4cyl 110kW
I am having the following codes
P0033 Turbo Bypass Control Circuit
P0034 Turbo Bypass Control Circuit Low
P0245 Turbo WasteGate Solanoid A Low
P0444 Evaporative Emission System Purge Control Valve Circuit Open
They come up on start up. I have replaced the turbo bypass and pressure conversion valve. As well as cleaning the MAP and the Boost pressure sensor and lots of other things. No change. The car runs ok.
Any suggestions would be greatly appreciated!
