Yesterday, the chariot was idling roughly, which was less noticeable while driving. This morning's newspaper run at about 8.30 am necessitated a 2km walk due to said chariot failing to start. Motor turned over happily but no indication whatsoever of it wanting to start. Kept on trying to start chariot, but not until the battery had gone flat. Been down that path before - if it doesn't start after a number of attempts, it's not going to.
Tried starting it again this arvo and "hey presto" - it started just fine! Now also idling normally.
Took it along and got the codes read - "knock sensor" and "vehicle speed". Only ever use 95 ULP. Speedo sometimes goes down to zero, but it's been doing that for a few years. Was due for a new fuel filter about 16,000 km ago. Needs a new air filter as well, but it's not that bad. Could do with some new spark plugs.
I don't drive the car much and fill up when it gets down around a quarter full, which I did a couple of weeks ago.
Any thoughts on what is going on? A bit of bad fuel? At 22 years old (the car that is), I'm a bit suspicious of probably many things.
