I’m sure that he was expecting a few things, but a seller who tells the truth about the car is always appreciated. And, as I indicated, the exhaust doesn’t seem to me to be noisy. But my understanding of the Mexican RWC system is that it isn’t a system. It’s more like a hotchpotch. And everyone makes up their own rules as they go along. What one tester fails, the next one passes with no problems.Noisy mufflers and worn brakes are par for the course when you buy a 20+ yr old car.
Maybe the seller took off the good rotors and swapped them with some old, nearly worn out rotors?The rotors on the XM were so thin I really don't know how it had been passing rego for the last 5+ years!
Yes, I think that I’ve already been lined up to assist him with the task of bleeding.The brake pedal shouldn't be spongy - I think your friend should start by getting the brake fluid changed (which will involve bleeding each wheel, so that should eliminate any air). He might also need to investigate replacing the flexible brake lines. HEL Performance made new (braided steel) ones for me - hopefully they've kept the specifications for future customers!
Do you have contact information for that company, please?
Your car had shiny paint and excellent upholstery, too!?!?My 605 came with a very poor service history - more a history of neglect - but a policy of 'overservicing' on my part has been rewarded. Shiny paint and excellent upholstery does not equate to mechanical perfection.
It might be a known tactic for selling a 605.
This is a great list. Thank you so much. I’m going to pass on the whole post, but I’ll highlight this list.My advice to your friend would be to assume (unless he has receipts to prove otherwise) that his 'new' 25 year old 605 is overdue for a thorough service. The good news is that there is no timing belt! However he should at least check, and/or change:
* Engine oil and filter
* Air & fuel filters
* Spark plugs and plug leads
* Coolant
* Accessory belts (I think there are 3). Power steering belt is particularly prone to squealing
* Auto transmission fluid (this may need repeating several times at short intervals) - make sure filter (strainer) is cleaned
* Power steering fluid (just as important as the others)
* Brake rotors and pads (don't forget it has drum rear brakes for the hand brake - inside the rear disk rotor for the foot brake)
* Brake fluid
* Radiator cooling fans - both should come on at low speed at about 90C, and when air conditioning is operating
** Others please add things I have forgotten
I have experience of a hot-dog muffler on one of my 504s. I couldn’t wait to get it off!I have not had problems with exhaust pipes as such, but all mufflers have been replaced. DO NOT allow the muffler man to put a cheap hot-dog in place of the middle muffler - it will produce an annoying droning noise just at the speed you want to cruise at.
But I was doing some research on 605 exhausts the other day and came across a crowd in Perth (three locations there) who specifically mentioned the 605. I couldn’t believe my eyes! I contacted them on behalf of my mate, asking them about their services. Unfortunately, they want the car, as they custom fit the exhaust. I did suggest to my friend that I’d take the 605 for a drive, but he hasn’t got back to me on that one.
First guess is that you tried the second hand parts route and you got stranded on a cold, wet, (or snowing) night near Guyra. How did I go?I strongly recommend that your friend should acquire an ignition module and a distributor cap as spares - he will need one or other (or both) sooner or later. A faulty ignition module will play up when the engine is hot; the distributor cap will do the same initially, then as it get worse the engine will misfire at any temperature. Don't rely on 2nd hand parts for these two - they are essentially consumables, and 2nd hand ones will probably fail soon after you fit them (guess how I know this)!
Where do you purchase these items? Are they genuine only, or is there something aftermarket?
Funny you mention that. The air conditioning was one of the biggest problems that he experienced, and it kept on being a problem for most of the time that he owned the first 605.If the aircon ever needs regassing, make sure the mechanic checks the pressures, as I have a theory that the weight of gas specified in tables used by mechanics is too low - too little gas leads to inadequate cooling.
I don’t need anyone to tell me about cold winters on the Northern Tablelands. My sister and her family lived in Armidale on and off from the early 70s until the early 2000s, I think is when they left for the last time.My 605 just started almost instantly after 8 weeks in cold storage - left to overwinter in a large, dry, but unheated shed on the Northern Tablelands (and 59 Floride will tell you how cold the winters are up here).
I’m interested.The old girl is far from perfect (leather seats rather hard - despite application of several leather dressings - and stitching is starting to go, speedo takes 10+ km to 'warm up' before it works, various dents and scratches - some from hitting roos), but it is still a wonderful relaxing cruiser.
I have to say that when I first got my 605, it didn't seem all that special. It's the kind of car that you appreciate more the longer you own it, and the longer the trip. If your friend finds his car a bit underpowered, tell him to check the throttle cable free play. There's a story there if any one is interested...
And it isn’t that the car was underpowered, but it wouldn’t kick down. He’s adjusted the accelerator cable to allow the kick down to come into position.
I’ve had many a car which have various dents and scratches and scrapes. Yes, some of them are from kangaroos. If I had had to get all of them fixed, I would be uninsurable. As it was, one company refused to reinsure me when I owned the 604. Two encounters with kangaroos in a year (much less than a year) probably put too much of a dent in their profits. But Shannons has never complained about the kangaroos I’ve hit. I can’t help it if they won’t look before they cross the road!
Thank you so much for this detailed post, Alec. I appreciate it, and I know that James will, too.
Andrew
