If you get the car up on wheel ramps so you can get a proper look from underneath, you'll soon work out if it's leaking oil. Aircon compressor sits below the alternator - if it's oily then it's pretty certain the alternator will be too. From above I can get my hand underneath the pump and wipe off any oil - can also wipe top of alternator
My alternator is still working, so I haven't had to try to get it out yet, but I believe we can do this job ourselves. I'm going to try it when I get all the bits I need. I want to do every possible job once I have the access.
My plan is to remove the nosecone and the radiator. Hopefully can suspend aircon condenser out of the way. Anything else? Anyway, with everything removed from the front it should make things possible. Other option is to remove engine/gearbox - Pugrambo would recommend this approach.
Jobs I am planning to do:
* Overhaul LHM pump. Apart from leaks, the pulley on mine wobbles. One of the bolt holes is stripped.
* Get alternator checked/repaired
* Replace accessory belt
* Repair or replace regulator (mine is leaking)
* Replace thermostat
* Remove auto trans heat exchanger, and install oil cooler (no official kit - yet to source parts).
* Dismantle headlights, polish everything (esp. plastic internal lenses), re-build headlights.
