Use plenty of adhesive on both the boot and the lining, I made sure the fit was good at the boot opening and then man handled the rest into position
Chris, what adhesive did you use for the hardura please?
Thanks.
Thanks.
I bought a litre of adhesive from a local trimmer, it looked and smelled like Kwik Grip contact adhesive.
(Sorry for the hijack Toby)
Thanks, Chris, I was wondering about the 3Mspray adhesive. I've just ripped heaps of kwik-grip like stuff out of Gills and it's awful to lift.... and seems to have rusted worse underneath this than anything else.
Chris,
If you go back through my thread you will see that I completely stripped the inside of the boot back to metal, made rust repairs, deoxodine, primed with 2K and top coated with 2K before fitting the lining.
The adhesive supplied by my local trimmer may have some rust inhibiting properties that Kwik Grip may not
Wurth do an automotive spray trim adhesive that would possibly be easier to use/apply, sprays a web of adhesive rather than just wetting. I'l be using this on my roof lining.
kwik grip vertical is super bonding, but you need to put on the material exact first go or you are screwed, I used it on heat proofing aluminium sheets, brush on both sides, plus the vinyl map pocket on the cabin firewall. Sikaflex contact adhesive on all other interior vinyl, works pretty good and not as full on an experience as kwikgrip, that stuff isn' very manageable. Make sure you do several dry runs on fitting as you'll want to have a good feel for how you're going to handle it when the glue is introduced. It can be a bit intense if you're not an auto upholsterer!
Well done Toby, Celia is looking stunning - nice temptation for some tyre squealing in that location :nownow:
You've probably got the filter change sussed by now, but still might find this video interesting (you can change the subtitles to English for even more fun). . .
http://youtu.be/UYjz80wZuHM
