I have some issues with Potentz!!. He is so withdrawn. Or maybe I am the braggart. Maybe this will bring a lot of responses positive and negative but as you know there are a few APPS that you can download on your phone to check acceleration etc. How accurate? I don't know but it won't be far out. This car does a 1/4 mile in well under 16 seconds. Correct me if I'm wrong, Potentz, and you don't need to blush, you've done a very good job!
Torque will be good because of the exhaust. Calculated extraction allows you to use lumpier cams that becomes effective at lower rpm. A heavier fly-wheel will only help you to not stall it at the traffic lights. A heavy fly-wheel will not help you to attack an uphill with better end speed. That momentum of the fly-wheel has lost its effect within 50 meters of starting the hill.
My old saying, a motorbike has no flywheel and is fast and a F1 car has no flywheel and is fast, so why have a flywheel?
Regards, Frans.
Regards, Frans.
