11BL instrument cluster re-wiring
citroenthusiast
Well-known member
Phoenix, Arizona USA
I need to do a bit of re-wiring behind the instrument cluster of the 11BL. How does one go about removing the instrument cluster? (I can't find any instructions in the workshop manual). Does the entire inside windshield trim need to come off? Thanks.
I believe that it does John. My car is 1951 and has the earlier windscreen garnish mould, so the instrument cluster comes away quite easily. Thank your lucky stars you do not have a Slough car with the square instruments. The whole dash board has to come out to work on those instruments!
OK, I was afraid of that. I just didn't want to start disassembling it until I was reasonably sure. Thanks. (Wiring is currently a bodge. Most of it is the wrong color relative to the wiring diagram, much of it with badly mangled crimp connectors and electrical tape.) I am already happy that I am adding some fuses.
