if it ain't broke?????
I only had her briefly before parking and pulling her apart, it ran well and but had an oil leak.Might not be too bad once you cleaned it all up - they always look horrible at first. 😬👍. Was it using a lot of oil?
Where (if at all) did you get it refurbished?Still at it. Had a little adventure with valves but sorted for now.
View attachment 135891 View attachment 135895
coming together slowly, now to dress the rest of the engine, refurbish brakes and clutch and baz back into the body.
Easy peasy…
Hi Sven, I saw your head at Headspec when I dropped my 6 cylinder one off, it’s been 3 months now so it should be nearly done.Frank at Headspec in Clayton did mine. Besides it taking forever (3months of pestering) he did a good job (well, I hope so, haven’t run the car yet, but it looked good - cost was about $1000).
He put in new valve seats and guides, welded up the water galleries that were corroded, skimmed and tested.
Sven
Just wondering what you are doing the tappet clearances at with inlet & exhaust valves ???Still at it. Had a little adventure with valves but sorted for now.
Easy peasy…
Didn’t, I cleaned it up carefully, had a long hard look at it. Then ran some very fine wet and dry on a flat plane around it, lay a flat edge around it looking for gaps, wire brushed out the coolant deposits, cleaned it again…Where (if at all) did you get it refurbished?
I really hope not to 😳What's the valve story? Are you going to have to pull the head again at some point down the line?
Going withJust wondering what you are doing the tappet clearances at with inlet & exhaust valves ???
John
Going with
Cold, Inlet 0.15mm, Exhaust 0.2mm
I’m nowhere near considering the Warm settings yet.
Have a look at: https://citroenclassics.wordpress.c...alve-clearances-tappets-on-citroen-ds-and-id/
thanks David, yes I have removed #3+#33 and bolt #32.It's fairly easy to make up a liner puller. Take a plate of rigid material (14" aluminium plate is good. Softer than the block/liner) and cut it so you have a disc of just under the liner bottom outer diameter (i.e. a fraction under the liner seat diameter), cut a strip off each side (enough to let you slip it down the bore and under the liner), drill a hole in the middle to take at least a 1/2" Bunnings threaded rod, sit a block of hardwood (drilled to take the threaded rod) on top four bolts screwed in where the head studs normally reside and use the threaded rod to pull it out of the block. No beating the life out of parts his way. You'd be surprised how this will free stuck liners, but make your life as easy as possible by cleaning and adding penetrating fluid. By cutting the strip off the sides off the disc, you can insert it down the bore and remove the liner without having to pull the crankshaft out. If you decide to beat the life out of the liners, strike you hammer or mallet on a length of hardwood.
The oil pump is driven off the camshaft and the diagram is below. Have you removed #3+#33 and bolt #32?
