Removing bolt attaching exhaust pipe to manifold
Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By bob
  • 1 Post By Johno1
  • 1 Post By Budge
Thread: Removing bolt attaching exhaust pipe to manifold
    Dec 2017
    Manilla
    37
    Default Removing bolt attaching exhaust pipe to manifold
    Hi all!
    Re my 1968 ID 19B, I have removed all the nuts but one which secure the exhaust to the manifold section. Is it a flange? not sure of the terminology.
    Access to this nut seems to be from below the vehicle following the exhaust upwards with a wabble socket and extension, but with the devices that I have it still won't quite line up or fit properly past the small curved heat shield.
    Just wondering what gear might fit or whether I am going about this in the correct way.
    John
    CitroŽn Tragic UFO's Avatar
    9,829
    You're heading in the right direction. You probably need a combo of short and long wobble bars.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    567
    Many years ago I cut an 11 mm socket down to make it as short as possible , just deep enough to grip the nut and extension bar , had to push up very hard to keep it on the wobble extension . They are a bastard to get at , Good Luck .
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Dec 2017
    Manilla
    37
    Oh yes, I had forgotten about shortening the socket.You did use 3/8 drive?Thank you both
    16,851
    Its been a lot of years since I've pulled a short stroke motor.... You need a good quality single hex socket. The obvious choice is one of your fathers sockets Grind that thing down until if fits. Don't worry, I'm sure he'll never notice if you get around to returning it
    The candle wax trick also works brilliant if the threads are rusted and frozen.
    seeya
    Mar 2005
    965
    IIRC these nuts on the downpipe are not full height standard nuts.....they are a bit like pyramids ( pointed on top ) so they do not offer a good flat sided surface for the socket to engage on. I think they are also split across the pointed top as well. This is the closest style I could find a picture of... intended to show how important it is to get the socket to engage straight and the need for maybe two universal joints in the "power line" between your hand and the nuts.
    https://www.allfourx4.com.au/90179-10128
    Mar 2005
    965
    This link might give you some ideas about what you are up against.
    Looking upwards into the dark grunge with all sorts of detritus responding to gravity !!!
    I note he replaced the original nuts at reassembly.
    Restoration of a 1968 Citroen DS21bvh Pallas: August 2018
    Dec 2017
    Manilla
    37
    The thought of my father with tools is quite entertaining
    And dangerous!
    Dec 2017
    Manilla
    37
    Quote Originally Posted by fritzelhund View Post
    I have removed 2 of the nuts with easier access and I don't think that they were that shape. I wonder if someone has already changed them. The vehicle has been a project by 2 previous owners, one of them twice and out of action for the majority of its life. So I'm told anyway. Possible that the last nut is original though. Impossible to see. Yes I did get the goggles out soon after poking up the channel. I have been lucky with this vehicle so far, touch wood that the nuts and bolts have all been easy to remove, accept the front seat belt anchors through the floor. Possibly due to the fact that it has been fiddled with and virtually no rust.
    I enjoyed reading about the paint prep in that article
    Jun 2011
    32
    If you undo all manifold to head nuts , move manifolds away from head a bit you will have access to rear stud
    bob
    bob is offline
    May 2001
    Skipton
    2,579
    G'day,
    harking back to a very much earlier life.....
    Common practice with rusty manifold nuts was to just use a nut splitter on the mongels and replace 'em in brass.
    cheers,
    Bob
    driven likes this.
    Dec 2017
    Manilla
    37
    Finally success,
    thanks to all the advice.
    On to the next step
    John
    UFO likes this.
    9,829
    Good! Now, while you have the manifold off, can I suggest that, unless you know the starter motor is absolutely faultless, that you remove it and find a reputable auto electrician to overhaul it? Or perhaps that's the reason you're taking the manifold off anyway.
    Ram
    Ram is offline
    Sep 2005
    Gayndah 4625
    54
    Hi,Yes you have been getting good advice. Once you have removed the removed the exhaust. it would be prudent to remove the two halves of the exhaust manifold and either replace the Starter Motor and associated external wiring of have it professionally overhauled.I have done a few engine and starter changes on DS21/D Special and fortunately have a very good Snap On 1/"Drive Socket set. Any make 1/4 drive set is almost essential to access the forward flange nut from underneath. I use the ratchet and or the screw driver with the kit, a 11mm socket and a universal , a 30cm & a 15cm extension . The 1.4 drive screwdriver is handy for replacing the nut. I use masking tape to hold socket , universal and extensions together with some rsidial flexibility.And dont forget a ground sheet to work on. Vey difficuld finding nuts and washers in the grass Happy daze
    Dec 2017
    Manilla
    37
    Ok, the vehicle started without issue when loading it on and off the trailer and driving it into the shed at home but yes my goal is to go over everything necessary as the car, from Gayendah, has not been in roadworthy condition for several decades and I have no solid history of what has been worked on.At the moment I am removing all the necessary components to allow the engine/gearbox to be lifted and checked over by a professional. I will include the starter motor to the next phase. On the list of what I still need to remove is;Gear ShiftThrottlePressure Regulator pipeFeed Pipe to tankBrake pressure feedI'm hoping that the workshop manual contains good diagrams of all these components!
    Apr 2016
    Bedford, UK
    849
    Hi
    Yes. Removal is covered in the manual. It's Operation Dm.100-1 in Section 1 of volume 2 of Manual 814. There are a couple of very good videos on Youtube about removing an engine from a manual gearchange DS. I used these (and the workshop manual) as the basis for writing out a checklist when I pulled my engine. Here is part one.
    Most recently, the "Servicing The Goddess" people have released a long (unedited?) video about removing the engine from a hydraulic gearchange car.
    Hope you find these helpful - or at the very least interesting!
    Budge/ Paul
    Trading Estate likes this.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Dec 2017
    Manilla
    37
    Thanks for the links,
    the one with the Charles Aznavour music I had seen but the second one is thorough, clear and methodical.
    I have just completed my list of work left, from the manual so that link should help me greatly identify the components.
    Very Grateful
    John
