oil temp BX
Results 1 to 3 of 3
Thread: oil temp BX
    Fellow Frogger! gsmack's Avatar
    131
    Default oil temp BX
    For those that read the cit board, you'll be away that I recently had a cracked sump, my solution...JB weld it...my question how hot does engine oil get?
    Not when it's sitting in traffic for an hr on a 30 degree day, but just running up and down the hume hwy for 2 hrs
    120 degrees?
    150 degrees?
    200 degrees?
    Any thoughts let me know
    7,557
    normal running 90-95
    working it hard 100-105
    flogging it on the race track 110-120
    why not pull it off and get it TIG welded properly? Or bolt on 2nd hand sump? Being PSA, there's plenty of XU type sumps around.
    Dec 2002
    Menzies Creek
    2,555
    Several years ago, I was restoring an engine that had a deep (1/16") gouge down the bore where a piston ring had broken and eventually gotten caught between the piston and the bore and gradually dug a trench down it until compression became too low to start.
    I filled the gouge with Devcon, then honed the bore and reassembled it.
    The engine still runs perfectly and has great compression.
    Moral of the story: I don't think the temperature that engine oil runs at will be a problem for any of the epoxy based repair systems.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
