2006 Berlingo Wheel stud pattern
Results 1 to 7 of 7
    Aug 2011
    Geelong
    10
    Default 2006 Berlingo Wheel stud pattern
    I am looking to put a set of alloy rims, not sure what size yet. Propably 16" - 17".
    When looking at rim, what stud pattern do I need to take note of?
    Any pics out there of some Berlingos with alloys fitted??
    Tim
    Newcastle
    2,811
    Default Stud pattern
    Hi
    As far as I know the small citroen/peugeot pattern is 4 stud 108 mm PCD. Not many other cars with this. The offset may be variable depending on the model.
    Jaahn
    May 2004
    Melbourne, Australia
    228
    Try this site:
    http://www.wheelfitment.eu/
    enter your model & it will show you what you have & which other vehicle wheels will fit.
    there are a few with the same offset (18mm).
    (you have;
    4x108, 65.1 bore, 18 offset, )
    spiz
    tweed heads
    1,545
    Default Ace sight
    Iv been looking for such as this many times in the past ,pitty it dousnt go into older models pugs
    12,283
    Quote Originally Posted by pugwash View Post
    how old and what models ?
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Fellow Frogger! Brett's Avatar
    Nov 2001
    618
    From memory Mi16 rims are a direct fit for series 1 berlingo, but they are only 15"
    Fellow Frogger! jurgen_s's Avatar
    Belgium
    707
    a 16" rim,7" wide would be around ofset 15mm, exactly the same for the 17" rim but an ofset of 18mm would be better, especially if you are going to use 215mm tires.
    www.peugeotforum.be
    Belgium Peugeot Club
