205 gti air pressure switch
    pmc
    pmc is offline
    20
    Default 205 gti air pressure switch
    Hi Guys
    I know this has been discussed before but can someone tell me how to bridge the air cond pressure switch as my system is gassed ok and pressures ok but the clucth on the compressor seems to have a mind of its own and work for a few seconds, then cut out
    I thought it may be a wiring issue with power to compressor/clutch or a relay but was told it may be a faulty pressure switch
    any comments would be appreciated
    cheers
    pmc
    Perth Western Australia
    2,705
    Quote Originally Posted by pmc View Post
    Hi Guys
    cheers
    pmc
    pmc,
    I don't know if things have changed much but air con systems have two pressure switches, one for low pressure, lack of gas. The other for over pressure, incorrect [high] gas level. Both will 'kick out' your compressor. The modern switch may be a combination of both ?
    Try "jumping" the switch wires for a short period to determine if it is faulty.
    19,215
    pmc,
    Most two connection switches are combined LO/HI pressure switches.
    Find the switch and short the wires briefly. Then find out why the switch has operated or you stand to do major damage to the aircon system if you run it for any length of time.
    pmc
    pmc is offline
    20
    Default solution
    Hi guys
    thanks for the advice
    looks like its a faulty thermistor under the dash
    my sparky says rather than replace, its better to swap for a thermostat.
    fingers crossed as it was cheezing me off
    Fellow Frogger! spar's Avatar
    sunny coast
    263
    Hey pmc, If you get it working can you plz report if it is worthwhile? In winter it should be freezing i guess. Mine is still in place in my 205 and supposedly was last regassed a few years ago but i have heard so many bad reports of them being useless i havent wanted to spend the money fixing it.
