306 s16 engine rebuid
Results 1 to 3 of 3
    castlemaine
    503
    Default 306 s16 engine rebuid
    I'm about to pull a very smoky s16 engine out for a rebuild. Are oversize pistons and rings still available? Anything other that I should be aware of?
    cheers, roger
    Fellow Frogger! Davo81's Avatar
    Mar 2011
    Kyneton, Victoria
    180
    I'd be very interested in the costing of the rebuild, Roger...
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,442
    Yes. You can get the pistons from a mob in Holland, dp engineering I believe. 87mm pistons are fairly cheap and give higher compression which is a good thing. About 900 Landed. Also look at using an 88mm crank if the budget allows.
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
