306 205 interchangeability and Imlachs stock.
Results 1 to 14 of 14
    9,473
    Default 306 205 interchangeability and Imlachs stock.
    I need a rear disc and caliper for the S3 205 GTi I picked up the other day.
    There is an 8 valve 306 XSi at Imlachs, question is will the rear brakes from this fit the 205, likely yes, but do they have the same size pistons?
    Also, will the light switch from this fit a GTi6?
    By the way there are at least two XU10J4R at Imlachs (Centre Road Wreckers, Springvale) mainly in late model Xantias.
    There is at least one DKZ, in a 405 and a few 8 valve XU10s, including the one in the XSi, by the way the XSi seats are very good, wrap around style.
    Also a heap of 8 valve 1.8 306 motors with the cam covers taken off, why?
    Graham
    266
    Graham
    Yes
    No - gti6 requires a twin optic switch; 8v is single I'm pretty sure
    9,473
    Graham
    Only one XU10J4R there now, in a 406.
    However, there is a 1.8 306 16 valve, may be a good 205 conversion as they have an alloy block with the late head so a lot of potential.
    I'd check the timing belt though, the car looks perfect, why is it there you've got to ask. These engines are $260 complete.
    Graham
    I might be slow... DRTDVL's Avatar
    Auckland
    1,288
    the rear brakes are either identical or marginally bigger on the 306, it wouldn't be worth worrying about... i've got a set of both under the house i could measure but if they are different the piston would be a mm or so larger in dia.
    9,473
    Quote Originally Posted by DRTDVL View Post
    Have to be identical as I'm replacing a brake that has smashed disc and caliper!
    I'll find out if they fit in the next day or so.
    Graham
    NSW
    634
    They fit but cannot be sure about the piston size.
    Buy both rear calipers and fit them to the car.
    Adrian Wuillemin
    9,473
    Quote Originally Posted by Adrian Wuillemi View Post
    Actually just remembered that I asked Ken at Caravelle and he said the repair kits are the same so should be OK.
    I'm just hoping the mounting bracket isn't bent!
    Incidentally I just fitted GTi drums to the back of the Si after overheating the originals badly in the rally a few weeks back. Seems to stop fine without any limiting valve (these are in the cylinders for the Si) so keep the fingers crossed that I won't have to source some more early GTi bits.
    Graham
    Auckland
    1,288
    i took both mine off the 306 and put them on the 205 so i know they fit.
    But i'll have a look tomorrow at the pistons.
    NSW
    634
    let me know if it is bent. I think i have one somewhere.
    Adrian Wuillemin
    9,473
    Thanks, will do.
    Graham
    Auckland
    1,288
    Graham
    Just read on 205 drivers that it's 205 = 30mm and 306 = 32mm piston size.
    Jan 2011
    Traralgon
    649
    Well, I'm about to try and fit a set of GTI6 front brakes onto my 405. Could be interesting. Haven't yet looked at the comparative piston areas, so not yet certain if the original master cylinder will math well with the revised layout. Not intending to change the rears thoug, so the other risk is generating an imbalance front to rear........
    Anyone done this conversion before?
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    7,555
    I don't think they'll fit without a very big hammer. I think you'll find you need 406 brakes. Best bet is to find a pair of 406 Coupe Brembo calipers, and even then you'll probably need wheel spacers depending on what wheel you use. Remove the compensator, fit a quality bias valve and re-plumb the rear.
    and 305x28mm coupe rotors
    9,473
    Thanks for that.
    They certainly fit alright and the caliper lines up straight so the bracket seems OK.
    Haven't been able to complete the job as one of the bolts is sheared and I'll have to get the broken piece out.
    Graham
