why not use wood
Results 1 to 25 of 42
    8,481
    Default why not use wood
    I'm in the process of finishing up a major service on my car, and decided that today would be a good day to finally tie the two floating chassis rail together with a butterfly brace. (for those who know the fuego, the entire section underneath the gearbox
    Unfortunatly I have $0 budget and have to use the products I have at hand, which would be alloy checker plate, galv steel sheet metal C beams, solid steel I beams, and.......form ply.
    I slapped myself when I thought of the form ply, telling myself you dont use timber on a car, and then I thought about it some more, and form ply seems aplicable for the perrfectly flat panel.... bloody strong, but not too strong in a major collision, easy to work with , flexable to a point, stiff to a point, abrasion proof to a point, basicly it fits the bill perfectly. Elastic on one angle and stiff as nails on another, and matching the forces I need to contain.
    I could even go and get some stronger thinner hardwood ply from brunziel.....
    I believe F1 cars have a wood plank under them, but I dont know of any other modern car that runs wood as a structural member.
    So, any reason why i should not tie the chassis together and use form ply timber as the product????
    Jo
    Sydney - Chatswood
    2,023
    Fire?
    Patrick
    Architect
    1991 Peugeot 605SVE (Written off 2007)
    1995 Peugeot 605SV (Bianca White) *SOLD*
    2007 Volvo XC70 Electric Silver (PJ-810)
    2009 Volvo XC60 T6 Teknik (Sapphire Black)
    2014 Volvo XC70 Luxury D5 Polestar (Ice White)
    2012 Mercedes Benz C250 (Alabandite)
    Past:
    1974 Triumph 2000Mk2, 1990 Renault 25TXE, 1986 Rover SD1, 1990 Peugeot 605SV, 1991 Peugeot 605SVE, 2001 Volvo XC70 and various Volvo 200-series
    Citroën Tragic UFO's Avatar
    9,809
    Morgans still use timber.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Jo
    The plank on F1 cars is for regulatory purposes.
    It is to ensure that they do not run the cars to low and the plank has to be a certain minimum height at the end of the race.
    That said, Plywood is basically a laminate.
    I'm not sure exactly what you had in mind - something like this perhaps?
    It should be ok as there have been entire Monocoque's built out of 3mm Plywood.
    Plywood should be quite stiff in a compressive plane - perhaps with a few right angle braces to prevent bowing? I assume you want to stop the chassis spreading/closing?
    Marcos built several different types of cars with a plywood monocoque and they were very successful in motor racing.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    I reckon if you put a piece of C beam (depending on the size) at each end to give it flexing stiffness you should be fine.
    The Plywood will have good stiffness in the pushing and pulling planes and the c beam will stop it bowing.
    You could drill holes in the c beam to lighten up a bit if needed.
    How close is it running to the exhaust?
    12,283
    it's a floopygo with a weezy 4pot, how much flex do you reckon there would be ??
    if it were PRV powered then there is no way it would hold together
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by pugrambo View Post
    Cornering forces dear liza, something your Buick by Peugeot would know nothing about...
    The idea on a Fuego would be to prevent the lower chassis rails flexing and changing the suspension geometry under heavy cornering loads..
    8,481
    Quote Originally Posted by mistareno View Post
    Wow, I never would have thought.....
    Yes nice brace that is effectively what I was aiming to do, but just with a slab rather than the butterfly cutouts.
    Of course a posh one like that would be nice, but no budget rules that out.
    As a tester, I grabbed the removable brace of the R25, re drilled the holes and bolted it up.
    Its not pretty but I should get some idea if there is a difference to be felt.
    It sits just behind the drive shaft hole.
    Jo
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Jo
    I wouldn't imagine there would be a perceivable difference in feel (you never know though), but it might add a bit of long term durability to the chassis as the cornering forces produced by a set of modern HP tyres are substantially more than the original 175 section tyres the car was designed for.
    12,283
    cornering forces the floppy's off the road doesn't it
    1 x 2018 3008
    16,747
    I'd be worried about it getting impregnated with oils .... so incredibly flamable at some point in the future
    Nov 2005
    Geraldton
    1,634
    Jo
    How are you going to mount it? Any fastners thru the ply would likely elongate the holes during flexing and nullify the bracing effect.
    Screwing and gluing? Given your well-documented affection for Sikafix you could bond some metal on to the board in some strategic places and get some serious stifness.
    I would think avioding oil impregnation is a matter of choosing the right paint/sealer.
    Trivia:
    Composites
    Modern F1 chassis are lighter and stronger than ever thanks to composite materials. One of the first major uses of a composite material in F1 was in 1966 when Bruce McLaren’s McLaren featured a chassis made of ‘Mallite’. This consisted of a layer of balsa wood sandwiched by two layers of aluminium and made for an incredibly light and stiff material. This concept is still used today except that the balsa wood has been substituted for aluminium honeycomb and the aluminium skin is today made of carbon fibre.
    http://www.forumula1.com/2006/f1/fea...s-and-chassis/
    Hey Jo, I think your next project should be replacing the dash. Let me see if I can find something on Bakelite for you...
    In the Shed(s):
    In the Past:
    lost
    11,055
    Icon6
    G'day,
    don't forget about termites.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    bob
    bob is offline
    May 2001
    Skipton
    2,524
    G'day Jo,
    your form ply is good stuff particularly if you can fix it without putting holes in it. You only have to really worry about moisture getting into it at the exposed edges - give it buggery with a good sealer around the edges and you're home and hosed as it were. If you are really fussy, stick it down with epoxy and paint the whole lot with a good layer of same.
    Plywood is good gear, they made fighter/bomber aircraft out of it during WWII, and very successful !
    Fix the exhaust up with a heat shield if you reckon that it's a bit close.
    cheers,
    Bob
    wielder of the sword Australdi's Avatar
    spinsterhood
    3,410
    Speaking from experience are you?
    I've done some serious corners on the tad side of "too hot" and never lost it once....perhaps some pug drivers don't have the same level of skills though
    Aus
    ".....the good health of a pond is held in a delicate balance. A pond's condition
    deteriorates when the bottom environment cannot support animal life.
    The bottom is the area that runs out of oxygen first, it is where the most oxygen is used........"
    '84 fuego GTX
    '87 fuego GTX
    '85 fuego GTX
    ....beginning to look a bit frightning isn't it.
    tweed heads
    1,544
    Default Google Marcos
    pretty sure they made a mini powered plywood car ,
    8,481
    Quote Originally Posted by bob View Post
    G'day Jo,
    Bob
    Why is that, rot and water ingress??
    I was imagining the wood would be clamped down with some sort of metal band on the wood side, but it would be the friction against the rail that actually holds it in place. In other words there would be no movenemt of nut shafts in the plywood bore, just a very strong clamping force.
    Jo
    lost
    11,055
    Icon6
    Quote Originally Posted by pugwash View Post
    G'day
    I had a 1948 2 1/2 Riley that had a wood frame. Used to move around a bit.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    12,283
    Quote Originally Posted by Australdi View Post
    hmmmmmmmmmm, i seem to recall a pic of yours with floppy in a ditch at the side of the road
    pug drivers are far too hot to fall off the road
    1 x 2018 3008
    spinsterhood
    3,410
    mine was in a ditch on a straight bit of track because the earth collapsed from underneath the left wheels.....no cornering involved whatsoever
    If you want to avoid answering...you have to think up a better example than that.
    Aus
    '84 fuego GTX
    '87 fuego GTX
    '85 fuego GTX
    Banned
    sydney, australia
    11,301
    di, you know what kind of a response that is going to elicit!
    12,283
    bloody hell they can't even head in a straight line without flopping off the road
    best be using some wood to put training wheels on then Nige and make up a set for Di while your at it
    1 x 2018 3008
    spinsterhood
    3,410
    hmmmm seems reading and comprehension are a challenge for some too
    sometimes I wear Prada
    Aus
    '84 fuego GTX
    '87 fuego GTX
    '85 fuego GTX
    lost
    11,055
    Icon6
    G'day,
    moderators at 10 paces
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    bob
    bob is offline
    May 2001
    Skipton
    2,524
    G'day Jo,
    Why is that, rot and water ingress??......
    spot on, you don't want any way for moisture etc to get to the edges where it can wick in. If there are no holes it's less edges to worry about, if holes are unavoidable treat them before the bolts go in and use big fat washers against the timber to give it more bearing area so it doesn't squash and allow movement.
    Might pay to protect the exposed edges between the rails with something solid, extruded aluminium channel or GI cover strip, stuck on with the sealer maybe ?
    cheers,
    Bob
