Fuel saving device
Results 1 to 15 of 15
    Feb 2011
    Nambour
    5
    Default Fuel saving device
    I know that some people think that many so-called fuel saving devices don't actually work, but I just want to get further opinion on this particular one.
    I have seen a device which fits fits on top of the carby and is basically a fan which spins freely on tiny bearings.
    Surely this will promote fuel mixing and not inhibit air/fuel flow as much as a fixed fan blade setup......?????
    If you turn a full a drink bottle upside down and swirl it, it will empty a lot faster than if you just upend it....
    Surely it will make SOME difference ?
    My car is a 505.
    12,283
    try it if it's cheap and let us know how it goes
    as far as i have worked out over the years things like hyclones, tin canisters () and the like are just a waste of time, money and effort
    you want better economy try water injection, i can tell you from experience that it works and it will cost you around $2
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    tweed heads
    1,544
    Default Interesting
    I wonder if its because the air is getting in faster that the fluid is getting out faster ,possibly fluid which is spinning will allow bubbles to move up quicker rather than glug glug ,there was some feed back on these a while back ,dont know pre or post crash PUGS
    Australia
    444
    I'm with pugrambo - surely anything that affects the airflow through any inlet manifold that has any value and not been adopted by any manufacturer, given their intended useage for the engine, is of no value.
    If it was, I have no doubt that the OEM would have fitted it from new in subseqent motors.
    Fuel is denser than air, and any device that spins the fuel / air mixture will only centrifuge the fuel droplets from the inlet mixture to the surface of the inlet duct, resulting in incomplete mixture, increased fuel useage and incomplete combustion. Engine designers take a lot of care to ensure their motors are as efficient as possible, or loose sales to more competitive opponents.
    Water - water / methanol injection has been successfully used in many early motors, dunno about recently. Same theory as nitrous oxide, that of adding more oxygen into the combustion process, but with the problem of valve stem / bore corrosion if not used continuously.
    fento
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Quote Originally Posted by fento View Post
    Whilst considered an 'old timers' science by some, water injection has had a major renaissance over the last few years as mapable electronic controls and proper fail safes make the metering more exact and the system more reliable.
    Water injection is now used on lots of highly tuned turbo/super charged cars as a way reducing combustion temperatures and adding resistance to detonation.
    With modern high pressure systems I have not heard of any problems with corrosion of the cylinder bore or valve stem as most electronic systems only inject water under high loads or boost where it vaporizes in the combustion chamber.
    Corrosion could be an issue with the older 'suction' style systems as they tended to suck in lots of unregulated water at idle and high vacuum (low engine loads) and could leave un-vaporized water in the inlet manifold and combustion chamber at shutdown.
    One known side effect of WI is that the internals of the engine usually look like they have just been assembled, even after 1000's of k's because no carbon builds up.
    It should be noted that if too much water is injected, wash down of the bores can occur which may accelerate engine wear - but - you'd have to dump in far to much water than ideally needed (or not properly atomize it before it is ingested) for that to occur as water and oil are generally not
    miscible in the amounts concerned.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,563
    Water-methanol injection was used in aircraft engines during WW2 to provide more power, with success. Water injection (home made) was used after the war to prevent pinging on low octane fuels and right through the sixties. The sixties also spawned large numbers of inventions guaranteed to save you fuel, double your horsepower, increase your top speed etc. Some were weird, some looked wonderful but they all had one thing in common! An immeasurable effect on the performance of your vehicle! And still the inventions came! Anyone remember Brock's Energy Polarizer?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,346
    Default Fuel Saving Device
    Hi All
    The best fuel saving device is the person behind the wheel.
    Fuel consumption depends entirely on how you drive the car, also how much un-necassary stuff you carry in the car and also roof racks.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    8,485
    fento
    I always thought water injection fell into one of those weird categories where we dont fully understand all the details of what and how it does what it does.
    Quote Originally Posted by Kim Luck View Post
    Or to get the poor suckers with not enough fuel to fly home a little close to their own line by leaning out and flying through heavy clouds.
    Jo
    Melbourne, Aus.
    18,563
    Hi All
    You didn't mention tyre pressures, wheel alignment, dragging brakes, and engine tune but generally I'd say you were on the right track!
    Following is an informative article about Water Injection that even mentions Renaults!
    http://www.rbracing-rsr.com/waterinjection.html
    12,283
    lets put it another way
    who has tried any form of fuel saving device and what were the results
    i have tried water injection and by using it being able to advance the timing = increased power and of course the prolonged flame front on combustion
    i for one have never seen any conclusive proof of any of the hyclone's, tin canisters, magnets and so on having any effect towards saving fuel
    1 x 2018 3008
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,777
    Default Fuel Economy!!
    If you want an older motor to be more fuel efficient, get rid of the carb and go fuel injection. TBI single point and a decent spark management will work better that a carb and dissy.
    Take That
    Ray geckoeng
    Think Old, But Run Modern !!
    Armidale
    2,606
    Quote Originally Posted by Okayitwasme View Post
    My car is a 505.
    If the fan were driven by something other than the air being sucked past it eg an electric motor, then you would have a super charger. However unless the thing could spin at very high revs, it would slow the air intake rather thgan enhance iit...
    Alec
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Jo
    Water injection is not the black art some would have us believe. It is best to think of water injection not as a power producing or fuel saving device, but as a facilitator of those functions.
    Water injection works in a very similar way to increasing the octane rating of the fuel.
    The water absorbs heat and reduces the auto-ignition point of the air fuel mixture - often to such a magnitude that far greater boost levels (resulting in higher power) can be reliably run.
    By staving off detonation, more advance and higher compression ratios can be run.
    Up until the last 10 or so years, there was the attitude that water injection was just a poor substitute for an intercooler, but now there is an increasing trend towards using both.
    FWIW, the most commonly brought up reference to Water Injection is the story that WW2(supercharged) P51 Mustangs could produce up to 70% more power for short periods with water injection and higher boost (it was commonly known as War Emergency Power - WEP).
    I have also read stories that state the throttle was fitted with a snap wire and if tripped by engaging WEP, the engine had to be rebuilt upon landing
    Fellow Frogger! Binky's Avatar
    15 Credibility st. Nth Fitzroy, Vic.
    227
    Hi All
    Amen!
    Alec
    Yes.
    ...Peugeot exploited centrifugal airflow on the 505 pre air-filter filter. Dyson has since made a good business of exploiting the same theory for their vacuum cleaners. If Peugeot has already explored this option as an air cleaning device, chances are they have also explored its fuel economy potential.
    At any rate, once the air/fuel mixture has entered the carburettor, it enters the inlet manifold and then is distributed to the cylinders. Whilst flow can have an effect on the combustion in each cylinder, it is difficult to envision that swirling pre-carburettor is likely to have much effect on the atomisation of fuel in air once it hits the combustion chamber... There would be a better chance of effect if a similar swirling device were to be fitted at the combustion chamber inlet. But then (as alluded to earlier) chances are that the fuel would be thrown to the walls and the combustion would be incomplete and very inefficient
    Sorry to be such a downer. I know how attractive these ideas seem. Twelve months ago I would have thought they sounded like a good idea. I'm slowly learning...
    Binky.
    Newcastle
    2,810
    Default The mystery? Why do people buy them !!
    Hi,
    Ricardo did a lot of research during WW2 on ways to increase power and prevent detonation in aircraft engines. This included water addition etc. It is all documented in books from the old days. It works. How that translates to todays cars is a matter of looking at the principles and how they fit The fuel was also crap in the old days
    Ricardo, for those unfamilar, was a famous engine designer in England, and designed a lot of the older combustion chambers which were used by most manufacturers for many years. Both petrol and diesel. His firm still currently does consulting to engine manufacturers.
    Try this site for fuel saving opinions
    http://www.fuelsaving.info/debunk.htm
    Jaahn
