205 gti engine wiring route??
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,012
    Default 205 gti engine wiring route??
    just a quick question, sorting out my mi16's wiring, i cant remember if it goes under the engine mount through the cavity in the shell, or just next to the timing cover (with corrugated plastic sleeve of course)
    can anyone shed some light on said matter?
    1,384
    Next to the timing cover and over the engine mount
    ...with engine mount removed
    Hornsby, NSW
    1,012
    aaaaaaah thanks pugmonkey i think i get it (but are you illustrating the wiring how it should be (then the mount bolted over the top, or just a photo with the engine mount off?) . i had mine going over the mount with it still on, caused the ignition module wiring to be too short and such. but i think it was because of my wiring running over the top of the cam cover at the back, not so much around it and through the fuel lines
    1,384
    Your right - the engine mount is off as I was just doing some work last night.
    Hornsby, NSW
    1,012
    ah, thankyou very much!
