s3 hubs versus si hubs
Results 1 to 13 of 13
    1000+ Posts djvu205's Avatar
    1,415
    Default s3 hubs versus si hubs
    can si hubs be made into s3 hubs by changing the centre to suit the gti 1.9 drive shafts. i want to get the wheels tucked in on the front of my s2 but keep the gti drive shafts. i am only guessing here as i was told si hubs make the track narrower when fitted to a gti but you need to use si drive shafts?
    9,467
    Quote Originally Posted by djvu205 View Post
    Si shafts are the same as GTi S1/S2 shafts. The S3 shafts are the ones that are different.
    Graham
    1,415
    Graham in what way are the s3 shafts different?
    brisbane
    2,924
    They have more splines than the earlier model....from memory 26 splines as against 24 or close there of.
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    9,467
    Quote Originally Posted by jr20516v View Post
    Yes, more splines and larger diameter on the wheel end, same as 405 shafts, but shorter of course.
    Inner is the same in all cases.
    Graham
    Hobart
    1,496
    Are there any advantages to running SI hubs on a Series 1 or 2 car?
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    9,467
    Quote Originally Posted by Pug_405_Mi16 View Post
    Yes, you can fit 306 brakes, including GTi6.
    Graham
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    And that would require a larger master cylinder?
    9,467
    Quote Originally Posted by DjB8V View Post
    Standard ones no, for the GTi6 you may need a larger cylinder as these can be too sensitive. Also, you may then need to change the rear compensator to bring the rears up ro the level of the fronts.
    Graham
    7,553
    You can also fit 206 brakes, in their various sizes. I think you definitely need to move up to a 22mm 306 m/cylinder if you put on 266mm brakes.
    1,415
    Default si hubs
    so you can fit a variety of non std gti brakes and it will make the front track narrower by approximatley how much? my c5 rims only just stick out on the front guards.
    1,415
    are the wheel bearings the same between gti and si?
    Mar 2005
    Here
    203
    Default How do you make a table in VBuli
    Reproduced without permission - because I can't remember if it was the UK or another 205 Board I saved it from.
    Hey - It's about sharing the grey stuff.
    Hope it's of use to you djvu205 as I'm a bit slow off the mark these days.
    Driveshaft lengths and splines
    For Peugeot 205 and 309
    "I made this table to see what driveshafts I would need for my conversion. 309 GTI driveshafts aren't very plentiful in junkyards. Also, I wanted to know to who I could sell the driveshafts I no longer needed. In this table you can also see what hubs will interchange without swapping the driveshafts as well. Could be useful when doing a brake swap.
    Note that a different line in this table means a different driveshaft (part number), even if all numbers match. There's one exception : diesels use the same driveshafts as 1.6 automatics. For instance an early 205 1.1 has different shafts than a 1.4 of same vintage. Probably the 1.4 axles are just stronger, but they will interchange. For example, I'm now running diesel shafts on my 309 and they fit fine, only they might be a bit less durable. Not mentioned in this table is the fact that ABS equipped GTI/CTI versions have different driveshafts too. That must have something to do with the wheel sensors, they probably don't interchange. The longest one (right hand side) always has a centre support bearing, except for early 205's that have equal length driveshafts without a centre support bearing. Those cars are also the ones where gear oil and engine oil are one and the same.
    Length figures are overall length, but compressed to minimum. Model years span roughly September thru August, so the '88 model year begins September '87. Thanks to the verbose catalogue at the parts store!"
    Car / Length /Splines
    type / model year /left /right / gearbox / hub
    205/ 1.0-1.1 (XV/XW)/ '83-'87/ 735 /735/ 22 /21
    205 /1.4 (XY)/ '83-'87 735/ 735/ 22/ 21
    205/ 1.0, 1.1 (TU)/ '88-/ 610/ 835/ 22 /21
    205 /1.3, 1.4 (TU)/ '88-/ 610/ 835 /22 /21
    205/ 1.6+aut all/ 600/ 845 /24 /21
    205/ 1.6 GTI+CTI/ all /600 /845 /24 /21
    205 /1.9 GTI+CTI/ all /600 /840 /24 /25
    205/ 1.8D/TD (=1.6auto)/ all/ 600/ 845/ 24 /21
    309/ 1.1-1.3 '86-'89/ 610 /845 /24 /21
    309/ 1.1i,1.4i '90-'93/ 620 /850/ 22 /21
    309/ 1.6 aut all 610/ 850/ 24 /25
    309/ 1.6, 1.6GTI '86-'89/ 610/ 850/ 24 /25
    309 /1.9 GTI 8V, 16V all/ 610/ 850 /24/ 25
    309/ 1.9D/1.8TD (=1.6auto)/ all/ 610/ 850/ 24 /25
    Perhaps we could check this for accuracy ( and format it in a table so it's easier to read )
    Sandgroper
    93' 205GTi
    'don't force it son - use a bigger hammer'
