XU9J4 XU10J4 extractors.
    Jan 2011
    Traralgon
    649
    Default XU9J4 XU10J4 extractors.
    I have finally found a supplier who has decent looking extractors for XU engines on the shelf (in Holland).
    The actually look pretty good. Individual header pipe for each port, 2 into 1 just off the head then balanced runners about 600mm long to the 4 into 1 collector. The connection at this point is the same arrangement as the original engine pipe - Torroid seal and compression spring connection.
    I haven't yet figured out how to post pictures, but if anyone else is interested in a bulk buy, email me and I can send you some further info.
    Cheers.
    Member 406bliss's Avatar
    Feb 2005
    69
    Default why not factory headers ?
    Sound good but if you want a set of genuine 4-1 for an XU10J4 I have some brand new GTi6 ones if you would like to make me an offer.
    From memory they are about the same length as you mention.
    Jan 2011
    Traralgon
    649
    Thanks for the offer, but mine is actually a 1.9L so the stud pattern isn't the same. Cheers.
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    What modifications have been made to the engine you want to use these on? Do you believe the standard XU9J4 exhaust manifold will be a restriction?
    Dave
    7,553
    Even the GTi6 pipes are too small at OD 1.625". I might be interested in 1.75" x 600mm if they're available.
