I would like to modify my 406
Results 1 to 24 of 24
    Feb 2006
    beecher QLD australia
    15
    Default I would like to modify my 406
    I would like to modify my 406 peugeot 2ltr twin petrol. I am thinking of decking the block and tacking some metal from the head. How much can you safely take from the head? Also pistons I need to go over size any way. So what is a good and where can I buy a seat of piston s for it. And if any body has any other good little ticks.
    Feb 2006
    15
    Default this is my 406
    This is her
    Attached Thumbnails Attached Thumbnails I would like to modify my 406-14042011.jpg
    Nov 2005
    Sunshine Coast
    350
    That car desperately needs a blow-off valve. Should be enough.
    Tim
    8,485
    Quote Originally Posted by krisdavid View Post
    ..... And if any body has any other good little ticks I could do to make it go hard let me no.
    I dont understand, on one hand you talk about performance, and then I see the picture of the car, and see anything but performance, the complete polar opposite.
    The bigest and cheapest mod you could make to that car is to sell those god awful wheels and put some ultra light rims in 15 inch with good high performance rubber.
    It wont matter how many horses you liberate with these expensive mods you are suggesting (not many), you'll still get beaten around a corner by a bog standard 406 with lightweight 15inch rims and possibly in a straight line too because of all the energy wasted turning the extra mass.
    Jo
    Ps
    Considering the car now looks like a VY commodore, have you considered getting a VY SS ????
    They come prety powerful from the factory and are getting to be bloody good value these days.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Jo
    Fair go Jo, personal preference is just that personal. He's lowered it and put on a set of wheels he likes, just as you have.
    I'm not saying that 18 inch Chrome wheels are the ideal choice as I'm sure they are heavier than stock but there is also no 'one' optimal tyre size or profile for every car and what works on a Fuego (and I personally thought 16's were better and I have driven a Fuego on both 15's and 16's) may not be ideal on a 406.
    I would've thought a 406 would handle fine on a set of 17's or 18's with HP rubber (the 406 coupe ran 16's stock and that was known more as a GT than corner carver).
    As for the engine mods, I think the engine is still related to the 206 GTi/180 engine so there should be plenty of info out there but the 406 is quite a bit heavier so having a high revving screamer may not be ideal.
    How about something like this - http://www.dp-engineering.nl/EN/proj...6_8v_turbo.php
    8,485
    Quote Originally Posted by mistareno View Post
    Maybe I should have just given the short answer like Tim's.
    My rims were chosen on just 3 criteria, weight, performance of the total package and price.
    On all three criteria they excel.
    Similar to the 406, I dont have a single watt to waste on turning a heavy wheel.
    I actualy think my rims look poxy, but I cant see them when i'm driving so I dont care.
    You are probably right, 16 inch is possibly the ideal performance size for this car.
    Jo
    Fellow Frogger! chez00's Avatar
    567
    Yeah the listing I have for the 406 says the 2.0L is an EW10 from 1999 onwards, same (family) as the 206. If it's pre-1999, it's an XU10 iron block by the looks of it.
    There are stacks of mods for these engines but most involve cams and head work, and thus expensive ECU upgrades and tuning. work out what you want to spend and then go to a good mechanic/machine shop and have a chat. The listing for XU10 pistons and rings at my work are about $180 each (i.e. $720 for a set) for Mahle brand (good). I don't have a listing for the EW10 motor.
    How do you know you need oversized pistons? It's not a particularly old car... Get a second opinion.
    Melbourne Australia
    1,382
    I think the obvious starting point for advice is to let people know what your budget is do you have one in mind?
    Secondly what do you hoping to achieve eg quarter mile records, slot car like handling, extra grunt towing a caravan ? Or just a 406 with a HP improvement when you put your foot down at any speed ......
    Feb 2006
    15
    This car Handles a hell of a lot better than it ever did when it was standard. As for the engine management system I am getting a motec computer piggy back into the standard system. I would like to know how much can be taken from the head with out going to far. And who in Australia sells good cams and pistons for her. The car is mostly for great HP improvement. I think if i have to rebiuld the motor i should do what i can to make it go as fast as it can i can do all the machine work my self. Thats why i am asking about how much can you take off the head.
    Melbourne Australia
    1,382
    Excuse my ignorance what's a banana headbang ?
    12,283
    drop petert a pm, he is a member here and will be able to supply you with either advice or some parts
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    12,283
    Quote Originally Posted by Andrew Ch View Post
    it's a QLD courting ritual
    1 x 2018 3008
    Melbourne Australia
    1,382
    Probably from where the line " not tonight I've got a headache " originated from : )
    Feb 2006
    15
    Yer it is in Gladstone QLD
    7,555
    Quote Originally Posted by pugrambo View Post
    It's closer to Magic. Although even Gladstone is a long way up the coast.
    Nov 2005
    Sunshine Coast
    350
    Hospital pass.........
    Tim
    8,485
    Quote Originally Posted by tcusack View Post
    Tim
    Peanut gallerie is firing on all cyl tonight.
    Jo
    1000+ Posts N5GTi6's Avatar
    1,119
    Why hasn't someone suggested the most obvious performance mod to any Frenchie here - someone sling him an AussieFrogs.com sticker for gods sake ! They're dyno proven to add at least 5hp !!
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    Half way between Brisbane and Ipswich
    244
    Don't see the resemblance. Those are wheels from a VE SS, and the 406 body looks more VT to me
    A friend of mine has those wheels on his Crewman, they're 19" and look too big even on the biggest Holden
    In regards to power: Turbocharge it. As bogan as it is, it's the easiest way to get more power without spending much money. If it's the EW10 engine though, they're very lightweight, and I've heard that 13psi is the absolute maximum.
    If you wanted to stay away from a turbo the EW10J4 (at least in the 206), has 10.8:1 compression already, so shaving the head would be a bit crazy. I've been told that the stock cam has very low duration too, so a regrind would make sense to do before shaving the head.
    Also, watch out for the police. Machining 4mm out of the bolt holes on those wheels was against the law
    8,485
    Quote Originally Posted by Blufires View Post
    Smartie.....
    Jo
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Actually, I think the wheels are aftermarket Chormies - Vault Crystals I think.
    They are a direct fitment
    Member 406bliss's Avatar
    Feb 2005
    69
    Default Headers ?
    I've got a new set of GTi6 stainless steel factory extractors that fit the 406 D8 XU10 engine. You just have to cut the engine pipe and move the flange down to suit.
    Gti6 Cams can work if you retune it but larger longer duration cams only work with throttle bodies or delusional folk. unless you go for the XU10J4RS inlet manifold injectors etc,etc...because the gas flow theory is different on the Gti6 engine.
    Service it, Powerchip it (cheap compared to an ecu change) get a firesale Remus if you want some noise and then go and do a driving course...after which you will probably put your wheels and suspension back to standard. (but we all have different tastes)
    Have had both D8 and D9 2.0 man 406 and they were good cars. I understand your enthusiasm.
    Best of Luck.
    244
    Ahh, right you are. They are so similar to VE wheels. The star in the centre gives it away when you know what to look for .
    As far as cams go, it's been shown on dyno runs that longer duration with a little less lift can make the XU9 engines put out more power, surely the XU10 would be very close? That is with the same manifold without even tuning the engine.
    Jul 2003
    222
    Just buy a faster car or one that has already been modified. It will be far cheaper.
    1992 205 Si
    Current: shortened diff (4.4), short shifter, group N top mounts, rebuilt engine and box, solid engine mounts, 1.75" exhaust, strut brace, OMP wheel, GTI suspension & subframe front and rear, lowered 30mm front and rear, solid rear bush, Koni yellows, 306 XT front discs and calipers, ADR compliant braided brake lines, 14" rallye wheels, Dunlop Direzza Z1 Star Spec tyres, immobiliser
