r10 gearbox assembly - help wanted
Results 1 to 3 of 3
    Nov 2005
    Geraldton
    1,634
    Default r10 gearbox assembly - help wanted
    Just acquired a 330-24 gearbox. It looks sound and it had a thick layer of oil and assorted crud protecting it from premature oxidation... Decided to address the oil leaks, install it and see how it goes.
    Some questions:
    1) What is the best way to get the side seals out - I have disembled the gearbox and have the bearing carriers out.
    2) there is what appears to be the remains of a fibre washer/gasket at the base of the cylindrical case that holds the needle bearings on the halfshaft pivots (trunions). There are none in the gasket set, are they critical and what is their purpose?
    3) Is there any product on the market that is superior to the Permatex aviation sealant for sealing the halves? (been a while since I've done a Renault gearbox...)
    4) Any general tips re getting these boxes not to leak?
    All the best
    P
    In the Shed(s):
    In the Past:
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    561
    All the best
    P
    Loctite 518 , gasket eliminator .
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    It's how I roll...Brisbane
    33,947
    My 330 gearbox used to leak like buggery until I discovered I had the wrong thickness gasket behind the bearing carriers...I changed the 0.4mm paper gaskets for 0.2mm and that is all it took to fix it.
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
