Missing tailshaft spring --404 hypoid diff
Results 1 to 18 of 18
    Apr 2003
    389
    Default Missing tailshaft spring --404 hypoid diff
    I need the spring that sits in the rear of the tailshaft ( pushes against the input shaft of 404 wagon hypoid diff).
    Don't have a sample or know the length of spring????
    Any informed advice would be appreciated...spring length, diameter; alternatives or sources for a replacement spring!
    Thanks in advance
    John
    19,218
    Quote Originally Posted by bahay View Post
    Thanks in advance
    John
    I lost one too and subsequently found it - I'll have a hunt to find it again (I need a spare) and measure it up.
    Apr 2003
    389
    Thanks Rob...look forward to your reply.
    John
    19,218
    John
    Hi John,
    For the life of me I can't find the spring. I'll just have to keep looking .
    I assume you mean Worm Diff, ie Sedan, not later wagon with the hypoid?
    cheers
    Rob
    Apr 2003
    389
    Default hypoid
    Hi Rob,
    It's actually a 404 wagon diff and torque tube I'm playing with this time. The spring will probably be the same/ very similar to the sedan/worm arrangement though.
    I pulled an inner valve spring off acylinder head and although it 'looks' okay, it's too long, too many coils, slightly thick 'wire' and probably too small in overall diameter.
    If anything turns up let me know...Thanks again
    John
    Member Grenouille's Avatar
    NSW, Aust
    115
    I have one JB,
    do you really want me to go out in the rain to measure it? or are you under control now?
    G.
    NSW, Aust
    115
    ok - it was a good excuse to go figure out where it was -
    20 x 2mm wire - 34 oal x 6 coils
    rgds
    G.
    Attached Thumbnails Attached Thumbnails Missing tailshaft spring --404 hypoid diff-2011-05-25-404-worm-diff-001.jpg
    Perth Western Australia
    2,705
    Somewhere in the windmills of my mind I recall that spring being identical to a 404 valve spring?
    Grenouilles measurements will prove me wrong no doubt.
    Oops, sorry you are talking about hypoid diff. Possibility it may be the same as worm diff. Peugeot can be like that.
    19,218
    504 TI inner spring is: (I don't have a 404 spring off a car)
    Wire Diameter 2.8 mm
    Free Length 39mm
    Turns (inc ground ends) 9
    OD 20.2MM
    So quite possibly a 404 inner spring is a suitable replacement
    NSW, Aust
    115
    Almost ditto Robmac,-
    404 inner valve spring =
    Wire Diameter 2.75 mm
    Free Length 40.5mm
    OD 20.0MM
    very close to the 504,-
    the compression on the valve spring compared to the diff spiring is roughly 1 - 3
    IE: when the diff spring is fully compressed the valve spring is only compressed approx 1/3rd of its free length.
    sorry i dont have anything to measure that tension for you accurately.
    see pic
    G.
    Attached Thumbnails Attached Thumbnails Missing tailshaft spring --404 hypoid diff-404_wd%7Ein_valve.jpg
    19,218
    Quote Originally Posted by Grenouille View Post
    Free Length 40.5mm
    OD 20.0MM
    see pic
    G.
    Coil Spring Rate Formula:
    11,250,000 - Torsional Modules For Steel (Constant)
    CSPWD - Coil Spring Wire Diameter (How thick is the wire?)
    8 - Constant
    NOAC - Number Of Active Coils (Coils that are free to move. Not coils seated. It may be that 1/2 of the top and bottom coil is seated causing a spring with 8 coils to have the distance of 7 free.)
    CMD - Coil Mean Diameter (The diameter from center to center of the coil. Measure the diameter of the coil from wire center to wire center. If you know the coil is .5 inches thick and the outside diameter of the coil spring is 3 inches, then the Coil Mean Diameter would be 2.5 inches)
    (11,250,000 x (CSWD x 4))
    (8 x NOAC x (CMD x 3))
    All Measurements in inches -
    404 Valve spring = 30.5 lbs/inch
    404 Prop Shaft spring = 18.75 lbs/inch
    18.5 / 30.5 = 0.6 near enough to 2/3 !
    NSW, Aust
    115
    Jb,
    You've got to be happy with that!!
    8 - Constant
    19,218
    rob, i get the formula as written, but i dont get the same numbers when i use it.
    for the 404 valve spring i used
    wire diameter .10826" ie 2.75mm
    mean coil diameter .67913" ie 17.27mm (ie 20mm - 2.75mm)
    number of turns 8
    that gives..
    11,250,000 x 0.10826^4
    8 x 8 x 0.67913^3
    = 1544.625
    20.0465
    = 77 lbs/inch
    I used a java calculator on the website. I'm really not sufficiently interested to analyse the code behind the app.
    Either of us have the potential to make a data entry/ calculation slip.
    Let's just says your calcs are correct
    NSW, Aust
    115
    SO.......
    I think from this JB
    there is no hope in hell you can substitute that spring or you'll have all of us chasing you down the street pointing out that the diff in your car sounds like the "thrust spring" has too much tension!!
    Banned
    sydney, australia
    11,301
    I
    ok no problem. i deleted my post. just thought it might have been relevant to the discussion.
    Apr 2003
    389
    Default Thank you everyone
    Thanks ..... I was tied up yesterday and didn't get back to A/F.......
    Then BINGO! A most comprehensive discussion......it's amazing how a small inquiry can stimulate such a full explanation!
    It's much appreciated...
    now to find a spring armed with the correct info , calipers in hand.
    John
    Fellow Frogger! Phil Whitton's Avatar
    Bargo Sthn Highlands NSW
    273
    Default sprong ..... sprong
    sprong....thats the sound as the spring sprongs across the workshop floor to lodge a t the furthest most point under the heaviest piece of machinery/bench.
    OK I found one......... complete with ORIGINAL grease.....
    yours for the collection whenever.....
    ciao
    Apr 2003
    389
    Quote Originally Posted by Phil Whitton View Post
    ciao
    Ah Dr Phil....you've always got 'that missing part' on hand it seems....
    Many thanks...will catch up again soon.
    John
