ADR and state vehicle standards
Results 1 to 15 of 15
  • 1 Post By pug206gti
Thread: ADR and state vehicle standards
    8,485
    Default ADR and state vehicle standards
    This is an attempt to link the relevant departments governing design standards and the limits of modifications, both owner certified and engineer scrutinised.
    ADR (Australian design rules) are obviously a national standard pertaining to lots of things, but each of our states has its own dept which has a secondary set of rules which is specific to each state.
    Maybe those from other states to NSW can link the relevent motor traffic dept websites.
    National.
    Third Edition Australian Design Rules.
    http://www.infrastructure.gov.au/roa...dr_online.aspx
    Read the page and follow the links to find the applicable ADR.
    NSW vehicle standards information sheets.
    Pertaining to owner certified mods, replacement wheels, window tint, noise, ground clearance and all those area's that may become grey when we start messing around with what the factory set.
    http://www.rta.nsw.gov.au/registrati...i/vsi_dl1.html
    Jo
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Victorian Vehicle Standards Information (VSI)
    http://www.vicroads.vic.gov.au/Home/...nformaiton.htm
    Perth
    239
    Default WA regulations
    Two options, depending on how keen you are:
    1. Modify a vehicle
    2. Construct a vehicle
    The first has a reasonable list of mods that don't need approval. But the list comes with the disclaimer "as long as they comply with "the applicable legislation".
    (Book a legal eagle to interpret it, before you book an engineer/mechanic.)
    "Democracy is the worst form of government, except for all the others."
    Winston Churchill
    (My benevolent dictatorship is the obvious exception)
    Gone Fishin'
    Aug 2015
    Nagambie
    1,937
    Our 'other' car is a Skoda Yeti 4x4 TDI (hmmm)
    It can't access the managed ski fields without modification, as in different wheel/tyre combination, due to the fact that as standard the specified 'diamond' pattern chains foul the struts.
    The Department of Infrastructure is not interested in my complaint to them as perhaps requiring Skoda Australia to make this seeming anomaly clear to a prospective buyer in any form.
    I suspect others may be effected.
    I wonder how many owners would know of this or have been carrying their chains without knowing they were useless?.
    My Hotham haven't responded.
    19,224
    There is some discussion here: Snow chains for 215/60 tyres DO exist! - Skoda Yeti - BRISKODA.net
    I wonder if a spacer plate behind the front rim is an easy, if no so legal , solution?
    Chains on rear wheels only sounds like a method of suicide.
    Simon's Avatar
    6,203
    What does the dealer say? I would think that would be the starting point rather than snow resort management. Given that it is a European car, I would imagine there would be factory accessory snow chains to suit the vehicle. Also given the variety of snow chains available, it should also be the responsibility of the owner, if they are heading to the snow, to make sure the chains they are carrying suit the vehicle they are going to be using. And given the nature of manufacturers nowadays, a generic set are unlikely to fit, you have to buy their "genuine" accessory.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    21,095
    I think you will find that they are into proper winter tyres as opposed to chains. Having driven of both, winter tyres are the way to go if you have proper winters:-
    "(4) - Germany introduced regulations in 2010 requiring all passenger cars and motorbikes including vehicles from foreign countries to be fitted with winter tyres or all season tyres on all axles when conditions are wintry. Winter tyres (or 'all season' tyres) should bear the mark M+S* or the snowflake symbol on the side wall."
    Rules abroad for chains and winter tyres | AA
    Every day is a good day
    Simon's Avatar
    6,203
    Quote Originally Posted by FIVEDOOR View Post
    That was another thought as well, given that some all-season European drivers appear to have two sets of wheels and tyres to cover all seasons. But I figured there may also be a chain set available for occasional travellers in other areas. Some handbooks may also provide information, I've also seen some say that chains are not suitable for fitting to certain model rims in manufacturer ranges.
    1963 Renault R4 Van
    1964 Renault R4
    Gone Fishin'
    Aug 2015
    Nagambie
    1,937
    The ski field management state clearly that you must carry ONLY 'diamond' pattern chains AND fit, when instructed, in the bays provided.
    NO other tyre, alone, is accepted as an alternative to chains.
    No European car dealer is going to tell you this prior to sale......when you've bought it you then find out in the owners manual.
    The FWD Yeti has the same wheel/tyre combo also.
    Sent from my iPad using Tapatalk
    lost
    11,055
    Icon6
    G'day,
    I had a look for horns, but found nothing. Can any one find a standard, or can we fit anything, for example.
    ..STEBEL® ITALIA - Trombe Horns
    or
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,563
    Quote Originally Posted by pug206gti View Post
    G'day,
    or
    I'm not sure what the book says, but there might have been a minimum db output for horns fitted to Oz manufactured vehicles. My take is the louder the better as long as you are not blowing them outside the girlfriends house at 3:00am when you are feeling horny...........
    Which takes us back to the original "Town and Country" horns fitted to vehicles like the R8's and early R10's..........
    19,224
    G'day,
    or
    Banned as far as I know. No musical or repeater horns allowed.
    42.18.1. General
    No siren, repeater horn, bell, exhaust whistle or compression whistle or
    other device capable of producing a sound resembling that produced by
    any such siren, repeater horn, bell or whistle must be attached to a motor
    vehicle other than an emergency community service vehicle.
    42.18.1.1. For the purpose of this clause, a repeater horn is any device which
    generates an audible sound (to be emitted) alternating between different
    tones or frequencies on a regular time cycle.
    https://www.google.com.au/url?sa=t&r...37132246,d.dGo
    lost
    11,055
    Icon6
    42.18.1. General
    G'day,
    oh dear, too late, never mind. Catch me if you can.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Melbourne, Aus.
    18,563
    42.18.1. General
    The local lunch truck has a set of horns that announces it's arrival playing a full chorus of "Dixie", and does not appear to be banned. I don't eat lunch, so I'm not involved, personally...........
    And, is a Mr Whippy van using a musical or repeater horn ?
    lost
    11,055
    Icon6
    Quote Originally Posted by Kim Luck View Post
    G'day,
    like ours'. it is probably on private land, or. Commonwealth property.
    Or, they can't be bothered.
    Kim Luck likes this.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
