is there a fix for bent needles on a virage speedo and tacho?
    Nov 2005
    Geraldton
    1,635
    Default is there a fix for bent needles on a virage speedo and tacho?
    Installing a Virage dash in an R12. Is there a standard fix for needles that have bent in the heat?
    P
    In the Shed(s):
    In the Past:
    8,484
    Replacement seems the modern standard.
    The best on budget fix I have seen is toothpicks painted orange with survey paint.
    Jo
    1000+ Posts Beano's Avatar
    3,203
    This ain't a standard fix, but you could try supergluing a piece of wire onto the underside of the needle, then bend into position.....just use rubber gloves for the supergluing, it's a buggr when you get it on yer fingers. I had to sandpaper some off once.
    lost
    11,055
    Icon6
    Installing a Virage dash in an R12. Is there a standard fix for needles that have bent in the heat?P
    G'day,
    does it read fast or slow ?
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,336
    Default Replacement Needles
    Hi All
    The best way is to replace the needles. Adding weight will effect the balance and make the instrument inacurate. I have used the needles from R12 or R16 Jeager guages
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
