gti cam in a xu5
Results 1 to 7 of 7
    1000+ Posts djvu205's Avatar
    1,415
    Default gti cam in a xu5
    im towards the end of building a xu5 motor to freshen up the si a bit. i know it may have been asked before but cant seem to find much on it.
    Just wondering if it would be ok to run a std s2 gti xu9 cam in it to give it a little more poke, rather than the std si cam, without to much trouble?
    its had 1.5mm off the head new guides 3 angle valve seat etc with std bottom end. i did the calcs a while ago now but hoping to go from 8.95 to around 10.4 ish? i will be using a baker adj cam gear and filing out the mount so it all sits back together and i can get it tuned up right. its only a daily drive that i want to have some fun in while i fix up something else.
    7,557
    I don't think the S1/S2 GTi cam (DFZ) is that much different from the Si cam. You should be looking for a S3 cam.
    1,415
    Default cams
    peter i do have another cam the spec sheet says it is 280 degrees has around 11.9mm lift. timing 30/70 70/30. lift at top dead centre is 2mm.
    would that spice things up a bit with out going to crazy? i plan on running a carby/ carbies if std si injection isnt up to the task.
    7,557
    If you've got >10:1 then definitely use the 280 cam. With only 2mm (0.079") lift @ TDC it's still quite acceptable for road use. The Si manifold and TB will strangle it.
    1,415
    Default cam
    thanks peter will do. i am going to experiment with a cut down si manifold that is opened up in the throat area where the carby bolts on. i have made a base plate to suit a 32/36 cortina carby. failing that im building a twin weber manifold which is a bit off being finished yet i have only made a model to check for size and clearance etc. i only have twin 40mm dellortos not webers but was assured from my carby guy he can tune them ok.
    Ipswich, Queensland.
    1,963
    Quote Originally Posted by djvu205 View Post
    Nothing wrong with Dellortos over Webers. Just a bit more parts availability from more places with the Webers. 40s with 34mm venturis would be a start for your motor with mods. 34s are the biggest you should fit to a 40, and were the biggest Weber sold for theirs.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    9,474
    Si 370 thou lift, DFz 400.
    Graham
