Head Job in Brisbane
Results 1 to 9 of 9
    Dec 2010
    Sunshine Coast
    32
    Default Head Job in Brisbane
    Yeah, yeah - not what you think.
    I need a 505 head skimmed after a blown gasket. The machine shop in my country town has shut down, and I'm looking for a competent machine shop in Brisbane to do this simple job.
    Any recommendations, please?
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    Chilton Engineering Qld
    6 Deshon Street, WOOLLOONGABBA, QLD 4102
    Brisbane Inner South, Inner City Brisbane
    p: (07) 3391 1672
    Always great work.
    Dave
    Dec 2010
    Sunshine Coast
    32
    Thanks Dave - much appreciated.
    Mar 2011
    Brisbane, QLD
    137
    I know Chiltons personally, they are who i would have recommended also
    1000+ Posts Beano's Avatar
    3,202
    Chiltons USED to be my preferred shop, because they know 504s and 505s well. For many years there was a Peugeot repair shop only 2 doors away.
    But last time I was there they shaved a cylinder head which I later took to another machine shop for something else.....it is closer to where I live. They took a look at the way it was shaved, with circular lines going across it....it was a rough cut with an almost semi-circular uneven surface from the machine. They commented that no-one shaves heads that way these days.
    Ipswich, Queensland.
    1,959
    Quote Originally Posted by Beano View Post
    How do they do it? I have only seen it done on a dedicated head milling machine(?) with a cutting head approx. 200mm across which will leave a slight witness mark of semi circles across the surface.
    I would also recommend and have used Chiltons, but generally use Liddles Cylinder Head service at Sumner Park. Both do plenty of work on racing machines as well as the mundane forklifts etc.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    3,202
    Yes, they use a giant milling machine as you describe....of the old variety. They have another type which leaves a really smooth surface, but didn't use it this time, despite charging me well.
    The thing is : David ( the owner ) does not LIKE Peugeots. And though his workers do very good work, I think other places are just as good, if you give them a stern warning about not shaving off too much. And you need to talk to the person who actually does the shaving, too !
    7,552
    The same at the place I use, Rams. They have a Bridgeport mill with a multi-tooth, large diameter cutting head, but with only three teeth, spaced randomly. It leaves an impeccable finish.
    1,959
    [QUOTE=Beano;935028] thing is : David ( the owner ) does not LIKE Peugeots. [QUOTE]
    I would guess after getting so many badly corroded 504 and 505 heads to weld from all of the various Pug repairers in the area, I wouldn't like them either.
