306 Question?
Results 1 to 7 of 7
Thread: 306 Question?
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,467
    Default 306 Question?
    What are the symptoms of failed bushes in the front wishbones?
    Car has done only 84000km.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    May 2002
    642
    Front bushes are a pretty common thing on a 306, you will have a slight knocking sound coming from the front end which gets worse over bumps and the longer you leave it the worse the knocking gets.
    You can get Grp A mounts from the UK or just get a set of new rubber bushes and press them in. A lot of dealers/workshops will just get new wishbones and replace them.
    05' Megane 225 Cup
    Member Simon888's Avatar
    Jan 2011
    101
    Common problem. My 306 is a 2001, which I've had since new, and I'm replacing them for the second time next week. First time was around the 90,000km mark, now on about 150k. The knocking sound above is exactly the sound.
    Pugsy - Group A mounts, really? do you have a brand or something I can look for? That would be better, and just before I do them again.
    May 2002
    642
    Spook Motorsport do a solid rear mount and you can get harder rubber mounts:
    http://www.spoox.co.uk/catalog/produ...f145ec4a1c97e1
    05' Megane 225 Cup
    Jan 2011
    101
    Quote Originally Posted by pugsy View Post
    Great. Thanks for that. Having a look now.
    Feb 2006
    North Rocks, Sydney
    2,467
    Thanks men,
    may not be bushes, no knocking but steering wheel shakes on medium braking
    ABS problem?
    I guess I will have to get down and get under .
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    monbulk
    658
    Default Brakes
    We had a Xsara which is a 306 in diguise.
    After 60Kkms the disks were warped and needed replacement. A common problem, I am led to believe.
    David
