tapping
Results 1 to 25 of 39
Thread: tapping
    177
    Default tapping
    all
    started noticing a distinctive tapping from engine ... goes up with revs
    could it possibly be related to a new valve seat fuel additive i've tried ?
    ideas welcome - tappets?
    is a Series One 505
    Jeremy
    Dec 2002
    Menzies Creek
    2,555
    Jeremy,
    Your car is an STi from memory? It is unlikely (but still possible) to be VSR on the ZDJK engine, as they all had hardened valves and seats. Unless you have been running too much advance or a particularly lean mixture I wouldn't be too concerned about that.
    I have seen the camshafts and rockers wear in ZDJ engines with high mileage and not enough oil changes under their belts. It's only 3 nuts and the intake hose to take the rocker cover off and check. You will soon find a loose tappet by feeling each of them as you slowly turn the engine over to the point where each rocker is not contacting the camshaft.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    177
    Ta Scott
    i keep oil changes pretty good
    cheers
    JR
    Fellow Frogger! tomb's Avatar
    209
    Jeremy our mechanic fixed a similar noise on the GTi, certainly sounded like a tappett, but he guessed that it was something like a loose stud on the exhaust manifold, I think a no. 1 cylinder. He said he had seen it often.
    Dec 2002
    Menzies Creek
    2,555
    Good point Tom - the Pulseair plumbing on the 505s tends to rot away after a few years, and a minor exhaust leak through one of these would definately sound like a 'tapping'.
    Scotty
    177
    cheers guys - i did take it to Charles St last week and Stu said there were some interesting exhaust notes
    will start looking for a new exhaust manifold / front pipe etc
    JR
    Fellow Frogger! viragewagonman's Avatar
    Wagga Wagga NSW
    301
    my r20 has a similar noise at high rev's. I have just put it down to the cracked exhaust manifold that I havent got around to replacing!
    Michael
    now Renault-less
    1995 Ford Futura V8
    2011 Ssangyong Korando
    previous cars;
    81 Sno White R20TS S1
    72 Flame Orange r12 GL sedan
    78 Azure Blue Virage wagon
    75 ghost gum R16 ts
    74 Track blue r12 wagon
    74 Ghost Gum r12 wagon
    Lilydale, Melbourne
    2,101
    A worn exhaust gasket or loose manifold nuts on a 504 sounds like you have pebbles in the engine! It makes a terrible noise.
    John W
    1974 Peugeot 504 TI
    - now on the road
    177
    Default update
    the mystery lingers ...
    i've had a couple of bolts replaced ... in fact three on the torque tube-gear box connection and one on the exhaust manifold
    obviously this has boosted my piece of mind and got rid of that terrible rattle (which an exhaust guy said was the front muffler ) ... but the tapping from the engine remains
    it is coming from the inlet side of the engine, towards the back, under the throttle body ...
    and this morning i noticed that the speedo needle "ticks" in time with it
    as i was driving along at about 60 this morning - the speedo needle was bouncing in time with the ticking coming from the engine
    as i revved out, so did the frequency of the ticking and the bouncing speedo needle
    this could be a clue ... as to what, i don't know
    JR
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,344
    Default Ticking noise
    HI robjer
    I think you may have found your problem. Why don't you disconnect your speedo at the gearbox and go for a drive. I'm suspecting the speedo cable is the problem.
    Try it and let us know how you get on
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    177
    ta
    so how would that work - what is making the clicking sound?
    J
    8,485
    Quote Originally Posted by robjer View Post
    ta
    J
    The speedo inner is not traveling smoothly in its sheath.
    I dont know what exactly is clicking, as I cant describe what produces a sound that i have not heard, but either the path of the cable is wrong and/or it is worn out and needs replacing with a new cable.
    Sometimes giving the cable a slightly different path will change the sound or the needle bounce.
    I've bullied a few extra month out of old cables by lubing and re positioning them, but best to just buy a new cable (if it turns out to be the cable), especially with all the damn speed camera's around. A new speedo cable will pay for itself fairly promptly if the needle is bouncing and you cop a camera fine.
    Jo
    177
    great thanks Jo and Col - reckon this is progress
    JR
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,344
    Default Speedo Cable
    Hi Robjer
    I'm guessing the speedo cable is dammaged internally and the inner is getting caught up on the outer.
    I have noticed in the past that cars with flickering speedo needles have damaged speedo cables. and you said that the needle jumps around in time with the tick so i just put 2 & 2 together.
    By disconnecting the speedo cable you will proove if its in the speedo cable if the tick goes away when you go for a drive.
    This is not a guarantee just some thing that is easy to try and it will eliminate one more thing and it cost nothing to do.
    Hope this helps
    Regards Col
    1973 Alpine A110
    177
    so the ticking could be an electrical short or something?
    in terms of what it sounds like - like someone tapping the edge of a five cent coin on a stainless steal bench top
    much more noticeable in a cruise at lower revs
    once engine gets louder it is harder to notice
    will try it and report back ..
    ta
    Fellow Frogger! Binky's Avatar
    15 Credibility st. Nth Fitzroy, Vic.
    227
    It's not likely to be an electrical short. Your car has a mechanical speedo driven off the gearbox or transmission.
    Agreed that it could be the speedo cable, but before you replace it, just check that it is properly secured at the back of the speedo. I had a 504 which made a clicking noise like you describe, with the speedo bouncing, and it just turned out that the speedo cable had not been properly tightened on the back of the speedo at the binnacle.
    177
    Default update
    ah ok - a mechanical cable ...
    well i've attempted to disconnect the cable but it looked impossible (for me, with my tools and time constraint) to disconnect from the gear box ... so i disconnected it from the back of the instrument panel and went for a drive ... sorry to report that the clicking remains while obviously there is no ticking of the speedy needle because it is at rest at zero
    so..... my knowledge level being fairly modest ... has my test gleaned any more light on the situation
    on reflection and now knowing that it is a mechanical cable - i probably still need to disconnect the cable from the box to do a proper test - yes?
    cheers
    JR
    8,485
    cheers
    JR
    Yes.
    Jo
    177
    ok then .... ta Jo
    seems to me to disconnect the cable i will need a tiny little spanner ... about 1cm
    and have to reach up to the top of the box and try and undo the little bolt so i can pull the cable out
    any short cuts or tips to get this done? seems a very confined space ... not sure i have a spanner that small
    JR
    Dec 2002
    Menzies Creek
    2,555
    Can you hear the tapping when you're not moving? I'm guessing you can, since you were able to tell us exactly where it sounds like it's coming from under the engine bay. If this is the case, it's got nothing to do with the speedo cable.
    Scotty
    177
    Default update
    yeah you raise an interesting point Scott
    if i idle the engine and open the bonnet and lean in to the engine bay - the tapping can be clearly heard - in the location i mentioned before
    however, if i'm sitting behind the wheel i have to strain to hear it
    and when i take the car out on the road - tapping becomes quite pronounced while cruising along at low to medium revs
    as i said - the tapping seems to be in time with the ticking of the speedo needle
    it is possible that there are two different noises - one from the engine in neutral that is part of the normal (?) noise of the engine
    the other one is something else that becomes prominent when the car is driving in gear
    or ... they could be the same tapping
    as i said - it is a very short "tick" sound - a bit like a coin being tapped on a metal surface
    the frequency at about 3000 revs is approx 5/sec but gets faster and slower with revs
    cdt
    cdt is offline
    adelaide
    225
    shot in the dark, but maybe cracked spark plug insulator arcing to the head
    cheers
    chris
    1000+ Posts dino's Avatar
    Nov 2002
    4,787
    Have you tried putting a screwdriver to the engine...against your ear...this will locate "exact" location of sound...Obviously you make sure you dont let screwdriver anywher near moving parts ..eg, fan, belts...and obviously do not let it touch leads while holding metal shaft...be sensible please...Otherwise buy a mechanics stethoscope...
    dino
    8,485
    Quote Originally Posted by dino View Post
    dino
    I like your latter suggestion better.
    Stay tuned for Dino's hot tip......"How to best remove screwdrivers from your now enlarged ear canal".
    177
    will try disconnecting the speedo cable first
    i called a Pug guru today and got some instructions on how to do this - although the bolt looks damn hard to get to i will try with a little spanner and see how i go
    re tracking the noise - am not sure the two noises are the same (that sounds crazy )
    but ..
    have tried the hose-to-ear method with modest results - will try screw driver method next - ta Dino
    JR
