R10 mid mount
Results 1 to 3 of 3
Thread: R10 mid mount
    May 2004
    adelaide
    8
    Default R10 mid mount
    can you use an R10 gearbox in a mid-mount position?, if so how?, do you run the gearbox upside down or can you change the diff over?
    Would the same be done to make a R12 gearbox with a rear engine layout?
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Exchange the breather for the drain plug, turn the bell housing around on the transmission, and turn the swing arms over - has been done in a mid engined motorkana car using an R10 drivetrain.
    That keeps your swing arm suspension. Otherwise just use an R12 box.
    May 2004
    adelaide
    8
    Default mid mount
    Thanks......my current project is a fiat niki with body/engine conversion, havent decided on engine layout just yet but i did pick up an r12 gearbox yesterday.
    http://forums.mightycarmods.com/show...y-DIY-projects
