Wiring spotlamps
Results 1 to 9 of 9
    5,312
    Default Wiring spotlamps
    Pre-crash I asked about wiring a pair of spotlamps. For simplicity call it a 505. I got the advice I needed, many thanks......
    So I've fitted them and they're wired so they only come on by the switch on the dash. There's a relay fitted.
    Can someone please explain how to wire them so when they're switched on at the spotlamp switch they only come on with full beam?
    I'd like it so that if the spotlamp switch is off only the headlights are on full beam.
    Does that make sense?
    Anyway, help appreciated.
    Mike.
    Started out with nothing, still got most of it left.
    19,225
    Quote Originally Posted by catshamlet View Post
    Mike.
    At the moment you have the 12 volt +ve power feed to the dash switch directly from an "ignition on" fuse/circuit?
    Disconnect the ignition on feed and connect the switch feed to the headlight full beam circuit, probably best found at plug that connects the steering column combination switch to the main loom.
    Clear as mud in beer bottle?
    bob
    bob is offline
    May 2001
    Skipton
    2,543
    G'day Rob,
    ......Clear as mud in beer bottle?
    no problems, dunno 'bout Mike though, he's from over there, like SWMBO, could be in deep ..... here
    BTW, you are talking about the relay switching feed, Mike, not the power feed ?
    cheers,
    Bob
    5,312
    Default I just love all things electrical......
    The switch I'm using is the heated rear window switch. The wire that used to run to the HRW now runs to a relay under the bonnet.
    So is that all I need to do, alter the feed to the switch? Nothing to do at the relay end of things?
    Quote Originally Posted by bob View Post
    G'day Rob,
    cheers,
    Bob
    Not sure what you mean Bob. But hey, there's no smoke without fire!
    Mike.
    19,225
    Mike.
    Provided you have the relay contacts are fed from an "always live 12v" then all you need to do is to alter the switch feed wiring.
    5,312
    Thanks, Mr Mac. I'll give it a go.
    But I'll have the boys on standby, just in case........
    Mike.
    Attached Thumbnails Attached Thumbnails Wiring spotlamps-trumpton-fire-brigade.jpg
    Banned
    sydney, australia
    11,301
    my boys are always on standby.
    5,312
    Default Thanks Mr. Mac
    Thanks Rob, took the feed for the foglight switch from near the left headlight, works a treat. No smoke, no fire.
    From here, that feels suspiciously like a double entendre.
    Mike.
    1,160
    Wiring to make them come on when you use the high beams:
    Output from the existing high beam switch --> switch on dash for relays --> new spotlight relay trigger.
    So then when your spotlight switch is "on" - they work via the high beam
    When the spotlight switch is "off" they will never come on
