205 rear beams?
Results 1 to 15 of 15
Thread: 205 rear beams?
    9,467
    Default 205 rear beams?
    I am getting clicking and banging in my Si rear ends at present.
    The one in the white one suddenly started this and was still there after replacing the beam.
    Don't think its body flex as it didn't change when the weld in cage was installed.
    My red car has now suddenly started doing this after carrying a battery in the boot!
    It comes and goes, can be triggered by the slightest movement, torsional or both wheels at once, or may not appear at all for a while.
    Has anyone had this problem, my GTis never gave a hint of this.
    Graham
    1,384
    Mine has been doing that for the last three months but only when it has weight in the back. Actually it started on the drive down to Speed on Tweed! When I am driving alone its fine, when the kids get in the back, its a harsh "clack" from the RHS rear from any normal undulation in the road. I'm taking it that i'm up for new bearings in the beam. I was looking at new shafts and bearing kits from the UK, but now I see I can get a sleeve and bearing kit. Don't know much about these though.
    Moo
    Fellow Frogger! DjB8V's Avatar
    8V'ville
    919
    The Si and GTI beams are the same dimensions?
    9,467
    Quote Originally Posted by DjB8V View Post
    I believe the tube diameter is a little smaller in the Si.
    Graham
    1,384
    Graham,
    Have you had any experiance with the shafts having a sleeve kit? Apparently the repair kits have 2 bearings, 1 seal and two sleeves. The sleeves are use to go over the worn shaft.
    Moo
    7,552
    Incorrect free play on the torsion bars?
    9,467
    Do you think they need a spacer washer?
    I'll give them a tap on the ends with a hammer.
    No haven't had experience with beams except helping to rebuild one of Casnells.
    Sleeve sounds like a good idea though.
    I may have to rebuild the red cars beam so will consider this.
    I am using bronze sleeves, no bearings, on the rally car, just as soon as I work out whether to use the Si or GTi beam.
    Graham
    1,384
    Email reply to me from EAI -
    WE HAVE THE REAR BEAM REPAIR KITS P513100 AT A COST OF $47.50 + GST PER SIDE.
    WE DONí STOCK THE SHAFTS.
    THE REPAIR KITS HAVE: 2 BEARINGS ONE SEAL AND TWO SLEEVES . THE SLEEVES ARE USED TO GO OVER THE WORN SHAFT. HOPE THIS HELPS.
    9,467
    Quote Originally Posted by PugMonkey View Post
    WE DON’ STOCK THE SHAFTS.
    Sounds good, wonder if the bearings are over size to make up the thickness of the sleeves?
    Worth buying a couple before they become NLA.
    Graham
    Oct 2011
    Sydney/Southern Highlands
    129
    Default Any luck?
    Did you try the kit in the end? My rear end on the 306 S16 has just starting squeaking and clicking due to a few too many speed humps and hasty driveway entries, and perhaps lots of wet weather driving recently. The noise is coming from the rear driver side, and the camber is out, with the wheel about 3mms from rubbing the arch. It's also lower on that side. I'm not 100% sure, but I'm thinking someones fiddled with it prior to me, since that side was always lower and the shock doesn't look oem. Just wanted to see if you ended up doing it...
    Fellow Frogger! deltone's Avatar
    Perth
    392
    Had something similar happen to my si, as the rear beam bushes wear out i think that the wheels can get closer to the rear lower bumper spoiler. The corner of the arch would rub on the thread of the tyre if i had any weight on the back, sometimes sounded like a clonk, sometimes like a scrape. Load the car and check for clearence maybe??
    205 GTi T16
    205 CTi
    1,384
    Now I have had my beam apart, I can tell what the clack noise is. I'm sure it's the needle rollers in the bearing jaring between the worn out indentations in the shaft.
    Oct 2011
    129
    I have the same problem - the bearings in the trailing arm shaft have packed it in. Luckily I have a spare beam to swap out and it shouldn't be too much trouble. I might even rebuild the stuffed one if I get the chance - but wondered if you or anyone have tried the sleeves? What are the shaft and bearing kits worth from the UK?
    Half way between Brisbane and Ipswich
    244
    I had this issue on my 206 GTi but I ignored the clunking for a few months. What I have learned is FIX IT QUICKLY. The needles in mine had worn right into the rear beam, and no repair kits could be found (I never saw any at least), and thus I had to have a replacement beam shipped from sydney. This meant weeks off the road and $100 shipping plus the cost of a new beam ($650 for a GTi one, or $300 with drum brakes if doing a complete rebuild).
    If rebuilding the beam or replacing bearings, make sure to SURROUND the thing with thick high pressure grease. Both my old beam and the replacement from a wrecker had water pour out when taken appart.
    Peugeot 405 SRDT
    - Sports tractor, running Berlingo rear and GTi180 front suspension.
    Citroen C5 2.0 A - Magic carpet to float around on
    Oct 2011
    129
    Default Rear Beam Jobs
    Just replaced the rear beam in mine. Twas a bit of work, considering I I had to remove my replacement from the parts car, then remove the stuffed one from my car, and replace it back onto the parts car - so basically two rear beam jobs in a day. Everything went pretty well, bar the battery running flat on the parts car requiring the front grille be ripped off to pop the bonet to repalce the battery (for the remote central locking - for some reason the key only worked the ignition, not the doors.)
    For those interested, you can get bearing kits from EAI and Dapco that around $50 per trailing arm - which includes the two inner bearings (small and large), some shims/sleeves to go over the rooted trailing arm, and the seals. That's the next job for me I guess...
