Gti6 running Haltech ecu - idle control?
Results 1 to 2 of 2
    Fellow Frogger! patpug's Avatar
    614
    Default Gti6 running Haltech ecu - idle control?
    Hi, I'm fitting a Haltech E6X ecu on an XU10J4RS motor. Do I need to run the idle compensator on the inlet manifold or does the ecu make it redundant? ie can I just blank that hole on the manifold?
    The ecu manual talks about diferrent ways to control idle - a 'BAC' valve is mentioned, is that the same as an idle compensator?
    205 gti-6
    205 track car build in progress http://www.aussiefrogs.com/forum/res...-race-car.html
    7,555
    Best to give me a ring.
