Tool Talk - Page 58
Page 58 of 71 First ... 84854555657585960616268 ... Last
Results 1,426 to 1,450 of 1761
Like Tree418Likes
Thread: Tool Talk
  1. #1426
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    16,744
    I think Roger wanted one of these
    looks like it has the built in post hole digger as well.
    Excellent for drilling and installing horizontal holes and posts..........
    It's another lovely day! Again!
  2. #1427
    17,590
    Quote Originally Posted by Kim Luck View Post
    Fixed it for you....
    Mutual Respect is Contagious
  3. #1428
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,159
    Avoid. Cheap, yes, but weird non-standard design and looks pretty rough. If decent hydraulic design and functional but worn, $5000 would be cheap. New about $18,000 last I looked.
    Roger
    Kenfuego likes this.
  4. #1429
    bob
    bob is offline
    May 2001
    Skipton
    2,076
    G'day Shane,
    ....... The blades beat up a hell of a vapour cloud of water .... this is also full of onion grass.... Yet it still cut it cleanly as shown. I was amazed to find it cut all the onion grass off cleanly ( yeah don't worry, I went back 10minutes later and the onion grass was all standing up straight again .... sigh ... the rear roller had just flattened it out ... .does any mower in the world cut onion grass ?).
    yep, it can be chopped off at the socks. All you need is a few regular visits from the local corella or galah flock and you get a nicely aerated area instead....
    cheers,
    Bob
    ha ! USA smell chucker, it doesn't know about Aussie bird names - or bowlers with strange actions either...
  5. #1430
    15,906
    Quote Originally Posted by bob View Post
    G'day Shane,
    cheers,
    Bob
    I haven't seen that in about 25years. When there was no feed left (drought) we had big flocks dig up the entire acerage and remove all the bulbs. Amazing to watch. I didn't know what they were doing at first.
  6. #1431
    15,906
    Thanks Shane! No its a 12" bar. Yeah, it shouldn't be too worn; Dad got it new and only used it a bit, then gave it to aforementioned numpty who handed it back in its current state after giving it a hiding. It came back with the bar and chain covered in sand and we guessed he'd been cutting roots half buried. One of those where you remember a year later that you didn't get a tool back and have to ask for it.
    It's never even had a sparkplug change. I inherited it a while back and haven't had time to get it going.
    How do you tell if the bar is OK, not worn out? Or do they last ages?
    if you read the forums ... promacs usually only need a carby kit (about $8.00 including delivery online) and/or a fuel line to get working again. However ... I was talking to the mate I borrowed the commercial Husky saw from .... He lent that and his small stihl to a different friend to knock down some fencing with. He gave instructions that oil must be mixed at 30:1 ... and the chain oil tank will need to be refilled with each tank of fuel.
    Well he just went to use his saws ... Neither wanted to start ... and wouldnt' run properly at all. In frustraction they were pulled down. Both have heavily scored bores ... they were both obviously run without oil until they died. looks like they were run without chain oil as well.
    So if the promac won't start ... don't mess around ... drop the head off and make sure it wasn't lent to a moron that just put plain unmixed oil in it
    The obvious answer is to never lend out a power tool!
  7. #1432
    15,906
    The howard sure would be a fun toy
    For all your equipment hire & rental in Ballarat | Bylsma Hire
    Bylsma would be the guys to hire from. A lot of there equipment seems to be "Red Roo". real industrial quality gear. Certainly not cheap. I checked today about hiring a stump grinder. I'd be looking at a few hundred for 1/2 days hire for the hydraulic red roo ( you guide the cutter head with a joystick)
  8. #1433
    15,906
    Just be aware of regulation clearances from main cables and other hazardous services.
    FWIW data and telephone cabling is a prescribed activity and ideally is carried out by a licensed cabler.
    https://www.acma.gov.au/Industry/Tel...istered-cabler
    I'd at least get a copy of the "Wiring Rules" AS/NZ S009 .
    Getting wires behind plaster (without insulation ) is not hard. Drill the top plate and use some shower chain and coat hanger to hook the chain. Beware of open power points when using the shower chain.
    Removing the plaster seems an overkill.
    Rob will like this one .... I know I do some dodgy shit aroudn the house .... but I have nothing on the professionals. Steamatic has being doing mold remediation on our house. As a part of this they removed the kitchen roof plaster ... and one of them was bloody near killed. A heavy ( stove/hot water service HEAVY current) power wire dropped down as they removed the plaster. Get this, it was just sitting there with the wiring exposed at the end in the blow in type roof insulation (someone could have been killed crawling in the roof). A sparkie must have moved a hot water service at some point and left the old wiring just sitting there ). Bloody lucky one of there guys wasn't killed.
    They rang a sparkie. he turns up and just leaves it on the floor ( to dangerous for me to do anything about it ... I'm not going up into that roof). he just puts a plastic junction box over the conductors. FFS ... All the wiring for the air conditoner is hanging down, as is the new lights that have been added over the years. Bloody dangerous .... Fortunately someone smarter than that sparky .... simply switched the power off at the main switch that night and tied all the cabling up to the rafters, and isolated the "professionally added" wiring from the copper plumbing. The guys working in the house were most thankful there was no wiring hanging down in there workspace the following day ....
    They have finally finished, and builders are due next week to start re-plastering and fixing the house. I figured I better check the soft roof in the bathroom that I've known was always there (but I ignored ... well it is a wet area after all). I touched it and my finger went straight through .... so I broke there area out.... Luckily in the daytime for a change.
    Daylight .... I can see bloody daylight through the roof.
    seriously .... what sort of nuff nuff not only drills through a tile, rather than running a bracket over the top edge .... they don't seal the hole. I would have thought a bolt down seal as a bare minimum (not a splash of silicon that doesn't even touch the roof tile). You can tell by the installation it's been a professional installer that added that aerial ( I've already removed his wiring that was sharing frame holes with 240volt wiring ...
    Attached Thumbnails Attached Thumbnails Tool Talk-moldy_plaster.jpg   Tool Talk-roof2.jpg   Tool Talk-roof1.jpg
  9. #1434
    17,590
    Most likely the person who upgraded the hot water heater (to gas?) just disconnected the old electric unit.
    This is classic of the death traps in older roofs, set by people who should know better.
    And being licenced doesn't necessarily imply that regulations will followed.
  10. #1435
    8,068
    Well, now you know why we hate asians. I reckon any SE asian tradie would have done the same job at the same standard of crappiness for a lot less money. Apparently we like to pay for crap as my canadian colleague keeps telling me.
    ACHTUNG ALLES LOOKENPEEPERS
  11. #1436
    17,590
    My experience is that race does not effect skill set. And to suggest otherwise, without definite information, is both untrue and insulting.
    And thinly veiled racial vilification.
  12. #1437
    15,906
    Has anyone out there tried the cheap stump grinders you can buy these days ( well ... around $900 isnt really cheap ... ). I have about 15stumps to remove. It would probably cost me close to $1000 to hire a stump grinder for a couple of days .... or far more to have them removed professionally. If you could buy one for similar money .... then sell it on when your finished with it ...
    The local hire places does a big industrial joystick controlled unit @ about $500 for half a day. I imagine it'll take more than 1/2 day though.
    seeya
  13. #1438
    bob
    bob is offline
    May 2001
    Skipton
    2,076
    G'day Shane,
    seeya
    reckon out here I'd spend that half-a-day traveling, setting up and achieving competency !!
    Much better with that sort of gear to travel at your own speed, rather than having the heat on to be finished by a certain time...
    As you say, resale is always an option, although, such toys can be difficult to part with....
    cheers,
    Bob
  14. #1439
    4,520
    Dig them out. Some people pay to exercise...
    "We prefer to believe what we prefer to be true"
    Francis Bacon
  15. #1440
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,457
    Quote Originally Posted by JoBo View Post
    Hire an excavator.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  16. #1441
    15,906
    Yes, expensvie options are the easiest. As for the small stump grinders you can buy ...
    we that 12hours work just to remove that small stump .... wow they are SLOW.
  17. #1442
    7,563
    The obvious question is why remove them at all? The cheapest way is potassium nitrate. The local councils use chemical methods on the footpaths. You can buy preparations - they are often coloured yellow. It will take a couple of months and the wood will be easily broken up with a log splitter or the like.
  18. #1443
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,457
    I had 3 small stumps and a large one to remove, the large one was removed by a professional with a stump muncher ( these have a large wheel that look like carbide tips attached) and the small ones were dug out by hand using crow bar, shovel, old axe and one of my R12's.
    The professional cost about $80 20 years ago, job was done in about half an hour.
    Regards Col
    1973 Alpine A110
  19. #1444
    SWOTR
    3,118
    Depending on the size of the stumps, 15 is a lot of stumps to grind. $1000 may get you a cheap stump grinder which, assuming it lasts 15 stumps, may take many many hours/days to do your stumps.
    I had 2 stumps ground not so long ago and exactly remember the price but it was somewhere over $100 per stump.
    Digging them out could be an option if you are young and strong and are prepared to do the job over quite a long period of time.
  20. #1445
    17,590
  21. #1446
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,457
    Thats how farmers remove stumps.
    I was going to suggest this method but if you got 15 stumps to remove it may attract to much attention
    Regards Col
    1973 Alpine A110
  22. #1447
    SWOTR
    3,118
    I considered of that option as well but thought, nah, the thread could evolve to a how to blow things up thread.
  23. #1448
    Oct 2002
    Melbourne Victoria
    10,479
    Icon10 Good exercise digging stuff, sweat out the bad things of life...
    I used to endorse the Jobo method of keeping fit, but the old age thing seems to have taken away that incentive....., I can see why explosives become attractive, a short fuse might be conducive to fitness even with old age and arthritis ;pains.
    Ken
    COL likes this.
  24. #1449
    Warrnambool
    2,159
    Legally you have to use a minimum of 1 metre of safety fuse. That's 100 seconds to walk steadily and safely away from the blast site.
    Shane lives too close to his neighbours to casually blast some stumps.
    From memory, the stumps are not that big. The potassium nitrate method seems a good option to me.
    Roger
  25. #1450
    4,520
    Quote Originally Posted by Peter Chisholm View Post
    Shane is.
    Francis Bacon
