New Pics !
Results 1 to 25 of 43
Thread: New Pics !
    St Mary's Pennsylvania
    233
    New Pics !
    Thanks to our webmaster gibgib, I now have the other pictures of my 405 on the members page.
    Check it out. eek!
    2000+ Brad's Avatar
    2,404
    James...that is an great air box you have going there. Does it improve things much?
    Is that a 1.9 or a 2l donk?
    Have you had it dynoed?
    Have the quad throttle bodies made a difference?
    What other mods you got?
    I am just full of questions
    Brad
    7,552
    I don't know James. That air cleaner looks a bit phallic to me! How fast 0-100km/h and 400m? Perhaps we should have a virtual drag?
    Fellow Frogger! Mi16 Man's Avatar
    Canberra, ACT
    711
    James,
    Nice looking car you have there!!!!!!!! Engine Mods plus all that TLC really pay off in the "phwoooaaaa" factor!
    Just a quick question, how can yours be a Mi16 if is only a SOHC engine?? Looks pretty similar to my old 1.9 205 GTi engine. Hey, there is more work under your bonnet that Pamela Anderson so anything IS possible! :p
    "Take a Lion through a corner - FAST"
    Current Fleet;
    2010 308 XSE HDi SW [Vapour Grey]
    2010 VW GOLF GTI [Carbon Steel Grey]
    In the Family;
    2012 508 Allure HDi [Thorium Grey]
    2008 207 HDi XT [Bianca White]
    Past "Frogs"
    2008 308 XSE HDi SW / 2006 307 XSE HDi Touring / 2001 306 XSi / 2005 206 GTi180 / 2005 407 HDi / 2003 206 XT / 1993 SII 405 Mi16 / 1990 205 GTi / 2x 1985 505 GTi S1 / 1976 504 / 1982 20 TS / 1997 306 XR / 1992 205 Si
    Fellow Frogger! Andreas's Avatar
    Sep 2000
    1,200
    Looking good Daniel.
    PeterT, what would you suggest instead?
    I suppose a second airbox or atleast heatshield would be better?
    Brad it's a 1.9 8v with more power than mine.
    btw, they're carbs.
    Andreas
    233
    Originally Posted 17 February 2001
    Ok if you have a modified pug, post the details here ! Here's the breakdown on my 405
    Engine; ported and flowed head with larger valves 44.5mm inlet 38mm exhaust. Custom ground cam. Valves lengthened, rather than use of shims. Compression ratio 11:1.
    Twin 45mm DCOE Webers 36mm chokes fed by standard cam driven fuel pump via Holley pressure reg. at 3 psi. Four 3 inch nickel coated trumpets. Hand fabricated Alloy air box with large Simota filter.
    Exhaust; 2.5 inch from standard manifold and 405 Sti down pipe to a large twin exit Vortex muffler. Momo DTM stainless tips
    306 xn alternator bracket, mounted directly to the block of the removed standard 405 alternator bracket. This allowed fittment of the Webers !
    Bottom end; Mi16 8.5 inch flywheel balanced and lightened. Carbon fibre pressure plate, heavy duty cover. Crank, pulley and bolts all balanced with connecting rods which were shot peened with the crank. (Added May 2002)Forged flat top pistons, custom built forged liners.
    309 Gti gear box, nice close ratios !
    (I blew up the standard 405 box doing wheelies !)
    Suspention/wheels; Lowerered 80mm on Jamex springs, Koni 3 way adjustable shocks. Tsw Imola 17 by 8 inch, 215 45 Nangkangs ($120.00 each, cheap, cheap!)
    eek!
    <small>[ 21 May 2002, 01:03 PM: Message edited by: James ]</small>
    Sep 2000
    1,200
    17" x 8"...really?
    got any close up pics of the arches?
    I know what you needed to do to make them fit but i didn't think they were 8" wide.
    Mine are only 7" wide and needed arch work, problem is that the wheels i'm considering are 8" wide.
    Have you cut or compressed the springs?
    Got any dyno figures?
    Andreas
    7,552
    I thought we could have an online drag to see who's got the quickest pug. I know I won't even be close, but it would be interesting info. It could happen like this:
    Find your favourite stretch of flat road. Do 3 runs, 70-120km/h in 3rd (most pugs can do 120 in 3rd, redline for 205). Passenger and driver. Record and post the 3 times, plus average.
    Sweden
    53
    PetetT,
    Sounds good but i think its better if everyone with an mi16 to rev alltheway.
    Because for ex. i have wilder cams in mine and that makes it a bit slower at low rpm and faster at the higher rpm....
    At 120 km/h i was doing 6000 RPM
    Anyway i tried what you suggessted and i got on a very straight road:
    8.44
    8.55 Average 8,493 sec
    8.49
    My 405 mi16 (1.9 L 16 v)
    Kat. Removed
    K&N oppen air filter
    good Swedish sport exuast.
    Fast road Cams
    The ECU has not been altered but soon to be...
    233
    Andreas, im running Jamex lowering springs but have cut another two loops out of them, a bit of mucking around but I got it in the weeds......
    As far as the back is concerned the inner guards are gone. I also had to run a hack saw along between the top of the bumper rear ward to the wheel arch. This was then unceremonialy bashed to shit by a big hammer back into the wheel arch. I then sprayed the close clearance areas with white paint and kept on bashing metal bits that were touching as the paint was rubbed off. Had to pull the gaurds out a bit as well. No science just the need to get it low......
    Peter, I will try the virtual drag tonight.
    Later boys........ evil
    <small>[ 22 May 2002, 10:34 AM: Message edited by: James ]</small>
    Sep 2000
    1,200
    So you didn't need to respray the wings?
    Did you need to modify the rear doors at all?
    A guy with 18x8's had to apparently.
    Andreas
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    haha these virtual drags look interesting. i have a feeling james is going to put everyone to shame when he posts his times though.
    James: your engine bay looks awesome!! i would die to have mine looking that tidy!!
    keep up the good work!!
    Dave
    7,552
    I've just blown a starter motor, so won't be going 'til the weekend. While it was all out, I took the injectors for a clean. Below are the ml/30 sec. before and after.
    40 48
    39 48
    40 48
    38 48
    That's up to 25% leaner!
    We could always change it to 70-130, but I figured it wouldn't be fair for the 8 valvers.
    233
    70 to 120 in 3rd.
    7.60
    7.86
    7.75
    Average 7.736 seconds.
    Now the same exercise using 2nd and 3rd eek! gave much better results.
    7.10
    7.14
    7.17
    Average 7.136
    Second gear ran out at 110-112 ks, 3rd went onto 150-155 ks. Dont have the money to see how far 4rth and 5th will go ! eek!
    233
    Andreas:
    Andreas
    What do you mean 'wings' !? Ok I admit it fly's
    but wings .........
    No change to doors apart from those that I blow off other cars !!!!!
    If you are having so much trouble with clearance, I hate to say it, raise the car !
    I have my car lowered with enough space to slide my index finger between the top of the wheel arch and the top of the tyre, front and back.
    Lets see you virtual drag........... tongue
    Sep 2000
    1,200
    James:
    but wings .........
    sorry, i meant arches/guards.
    it's not that i'm having problems now, i'm just looking at other wheels which will be wider.
    as soon as i get my car back i'll go time it...on the freeway in the northern territory of course. wink
    Andreas
    Sweden
    53
    PeterT
    Did you notice a difference after you put back the injectors ? acceleration? drivability?
    Mine have done 165 000 km so it might be time to do something about it hehe
    James how did you test 70-120 ?
    I put in 3 rd and drove at 70 km/h then i slamed the pedal and waited to rach 120 ...
    Ill try 70- 130 today ill get back with info.
    /Samer
    7,552
    Good consistent times guys! Where's that 205/Mi16?
    I haven't got mine back together yet. Can't wait. I suspect I'll have to re-map the ECU however. I suspect I've had dud injectors for a long time, and the current maps are based on the flow from the dirty injectors. 25% more fuel is definitely going to be too rich. Mine has done 145K.
    2000+ Brad's Avatar
    2,404
    I only got a chance to do one 70-120km run tonight...too many cars on my chosen stretch.
    6.65sec @ about 6200rpm
    It felt a little hesitant on take off...i might try and load the engine up with some heal toe and see if that helps.
    Might also try it with shifting through 2nd aswell.
    2000+ Brad's Avatar
    2,404
    Update...did another few runs today,
    6.8sec for 70-120 3rd, but hows this...
    7.1sec changing from 2nd at 7000rpm/90kms/h eek! eek!
    7,552
    Good times Phasis! Makes the modified Pugs look sad! Just goes to show what that a difference the two stage inlet manifold makes. I got mine back together today, but as I suspected, mixtures where a bit rich. I'll tune it up tomorrow and hopefully post some times tomorrow night. It's so smooooooth though with clean injectors, it just has to be better.
    Fellow Frogger! AxGT's Avatar
    Apr 2001
    294
    70-120 in 3rd gear
    8.11 with 2 people on board
    not to bad for a 1.4L 8v
    Sweden
    53
    How could you get 8.11 in a 1.4L 8 v???
    I HAVE to give it another try wink
    Just for the rekord... :
    1) Are you sure its a straight road?
    2) Are you driving upp to 70 in 3 rd then waiting at 70 for a few seconds before you start acc to 120 ??? or are you guys acc and as soon as you pass 70 you start the clock?
    3) thats it hehe
    /Samer
    Apr 2001
    294
    citroen ax
    dry weight 730 kgs
    7,552
    PugPower,
    I think your car is sick. Phasis, you need three times to qualify. James, didn't you say once, that your car ate Mi16's? How's this!
    3rd 70-120
    6.87
    6.93
    6.79
    Av. 6.86 (I also did 6.00, but slightly downhill)
    2nd/3rd 70-120
    6.4
    6.87
    6.90
    Av.6.72
    405 Mi16 1.9 160hp
    Haltech E6A ECU
    MSD 6A ignition
    2.5" exhaust
