Cam driven or electric fuel pump ?
Results 1 to 9 of 9
    St Mary's Pennsylvania
    233
    Heading back to NZ for a month's holiday from Canada. Before I can drive my 405 (XU9J2 engine) I need to fix the damn fuel pump. Since putting the 45 DCOE Webers on I have had to make some adjustments. As the Webers like about 3psi I have a Holley fuel pressure regulator feeding them via the cam driven fuel pump. This is leaking and I think I have a fuel supply problem at the top end.
    Is it as easy as removing the pump and blanking the hole off. Then installing the electric pump ? question
    <small>[ 09 May 2002, 09:09 AM: Message edited by: James ]</small>
    New Zealand
    173
    Hey man,
    a bit off topic as I cant help with your fuel pump, but where in NZ you coming back to?? Christchurch right?? If so I'd be keen to meet up and have a look at this tricked up 405 Mi16 (is that right?) of yours.
    Hope you get your fuel pump sorted.
    Izza
    Fellow Frogger! PUG309's Avatar
    Feb 2001
    Sydney, Australia
    231
    James doesnt have a Mi16 it is the 8 valve motor, same as the one in the 205 GTi but it kicks arse...
    Daniel Djuracic
    Ex UK spec 89 309
    206 XT 1.6 16V (Diablo Red)with Peugeot Lion in back windows
    490
    Hey James, I had a 160hp 2110cc VW motor running twin Dellorto 45s, the standard cam driven fuel pump didn't have a prob with supply.
    I might suggest if it's not supplying enough fuel, maybe looking for worn parts in it maybe a cheaper option... ie the rod that the lobe pushes up and down might have worn down over time?
    7,555
    Most aftermarket electric fuel pumps like to "push" rather than "suck". ie they need a head of fuel to prime them. Why not use a std. FI pump in the tank, then use a regulator to drop down to 3-4 psi?
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    We were having a fuel surge problem on the CX GTi when we got it at first due to pump location etc. My son fitted an electric pump (capacitator type) at the rear of the car and used it to blow fuel through to a "surge tank" or swirl pot under the bonet which in turn fed the fuel to the FI pump. After stuffing around making swirl pots etc, it was found that a filter off an EFi Commodore V6 was a good size & efficiently did the job.
    This is a variation on PeterT's idea, only this way you end up paying $30 for a big filter and $60 - $70 for a pump, instead of $300 + for the pump plus whatever else you might need.
    These pumps work at around 5 psi from memory and simply cut out as the pressure is reached. May even be good enough to handle the job without resorting to swirl pots anf cam driven pumps.
    Fairly simple job tp wire into the ignition circuit.
    Alan S
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,343
    I think that if the mechanical pump is capable of enough flow, then stick with it. You can be always sure that a mechnical pump stops when the engine stops (i.e. in a crash). With electrical pumps, even with inertia switches, you still have the possibility of a relay shorting closed, etc. I'm not saying that electrical pumps are dangerous, just that mechanical pumps are a bit simpler and generally more fail-safe. Mechanical pumps are also dirt cheap to replace compared with electric pumps (e.g they're usually under half the price).
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    490
    If you do decide to go down the mechanical route, one trick my brother and I did on an old worn VW pump was to weld a tiny bit more length onto the rod driven by the lobe - worked a treat!
    I have no idea whether the 405 has the pump driven in this way though?
    233
    Thanks for the replies guys, I will tinker today and see if I have any luck. From what I can see the cam driven pump just needs a new gaskit. Have taken some shots on the digital cam so will have em posted under my car on the Pic site soon.
    I returned to Auckland not Chch sorry.
    Im one of those 'Ponsonby ******s' with a Peugeot in the drive.
    Later..........
